SweetJustice Posted June 30, 2017 Share Posted June 30, 2017 TLDR: Replaced both coils. No bubbles anywhere. System still leaks down to not working in 3-4 weeks. History as follows: 1. Local Subaru dealer diagnoses a leaky condenser coil, quotes $1400 to replace it. No thank you m'am! Bought an aftermarket unit off ebay for $80 and charged it with Redtek. 1b. 4 weeks later, no cooling. 2. Bought a UV light, figuring maybe the previous owner ran dye through it, or maybe I will. Pretty much the entire engine compartment fluoresces. Oh well. 3. Bought a fleabay halogen detector. It alarms on the floorboards. A-ha! Another $80 on ebay for a new evaporator coil, and I'm golden, right? It held 100psi overnight, anyhow. 3b. See 1b, above. 50psi static, 80/25 running. No cold. 4. Deep research into bubbles. Consensus appears to be: 250 mL distilled water, 25 mL Dawn (not Ultra!), 5 mL glycerin. Can confirm, it works very well in a bubble wand. 4b. Spray bottle time. Nothing. Sprayed the bejesus out of the compressor, as much of the condenser and its joints as I could reach, I even took the dashboard apart (*again!*) to spray the evaporator joint. Did the entire lengths of both high and low lines in the engine compartment. In desperation, I even sprayed the service ports. Nothing. Not a single bubble. Advice welcomed! Do I just keep replacing components one by one until I figure it out? Should I do the lines next or the compressor? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2017 Share Posted June 30, 2017 Most any local repair shop will be able to put a die in the system and look for the leak. Don't pay the dealership to repair your 11y/o car. call around to the car repair shops and ask them 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08SpecB_DE Posted July 2, 2017 Share Posted July 2, 2017 Did you replace all of the o-rings? Did you pull a vacuum after you cracked the system open? If you're in my area, you can borrow my gauges. I have an oil filler in-line on the low side so you can put some uv dye/oil in the system as well. Link to comment Share on other sites More sharing options...
cseagle08 Posted July 2, 2017 Share Posted July 2, 2017 did you check for leaks while the system was running? Maybe the heating/cooling of the various lines is causing a crack to open and leak? Link to comment Share on other sites More sharing options...
SweetJustice Posted July 3, 2017 Author Share Posted July 3, 2017 did you check for leaks while the system was running? Maybe the heating/cooling of the various lines is causing a crack to open and leak? Pulled down to about 400 microns, but it wouldn't hold below about 600-700. AFAIK, anything holding below 1000 means there's no more moisture, so I didn't worry about it. I chalked it up to old oil in the pump -- vacuum pump oil is hygroscopic. It didn't occur to me to replace the o-rings though. I don't see a spec for them in the service guide. Do I just have to buy the o-ring kits from the dealer? Link to comment Share on other sites More sharing options...
SweetJustice Posted July 3, 2017 Author Share Posted July 3, 2017 did you check for leaks while the system was running? Maybe the heating/cooling of the various lines is causing a crack to open and leak? Sadly, I didn't, at least not while fully pressurized. I did after it had leaked down to 80/20 psi, and didn't see any bubbles, and didn't get any action from my leak detector. It's a good idea, I'll do it after I replace the o-rings. Link to comment Share on other sites More sharing options...
SweetJustice Posted January 27, 2018 Author Share Posted January 27, 2018 So I took my $75 to the dealer for a new set of O-rings. Took the whole damned thing apart again, replaced the O-rings, pulled a good vacuum for two days, and recharged...lasted a week before it was dead again. Link to comment Share on other sites More sharing options...
SweetJustice Posted January 27, 2018 Author Share Posted January 27, 2018 The story does have a happy ending, though: after tearing the last little bit of my hair out, I took the car to a shop downtown that has a reputation for being good with AC problems. They washed out the engine compartment, did a dye charge, and found a leak at one of the condenser O-rings. He thought it was possible that I "rolled" one of the o-rings when replacing it, it's apparently something that just happens sometimes. Anyhow, they replaced the o-ring (no charge, they apparently only cost about $0.07 each when you don't buy them from the dealer), and it's been good for six months now. Link to comment Share on other sites More sharing options...
