SWP Spec.b Wagon build - my 4th LGT
Just pulled the trigger on LGT #4 last week, and couldn't be more thrilled. I've gone through 3 other cars because each one had something a lil different. Now at #4 I'm hoping to incorporate everything I wanted out of the others to hit my goal of decent track performance + a comfortable DD baby hauler.
My history:
Car #1) 08 Spec.b - Bought this car new in 09. It was my first Subaru, and first time modding my own car. Got it to stg.3 with an 18g, brembos, and RCE 9k coilovers. Tried almost every suspension part made for the car.
Car #2) Bing's 05 LGT 5eat Wagon - Sold the Spec.b and got this wagon to prep for upcoming baby #1. Came with a similar power build (18g) and a car audio install I've only read about in magazines. Swapped my suspension over enjoyed a couple days at Laguna Seca and Sonoma Raceway. Track days made me miss the 6mt =\
Car #3) 05 5mt Sedan - Picked up a totalled car locally for its built motor. Swapped the motor over to my 5eat wagon, and sold all the other parts to recoup funds. Shell went to the junkyard
Car #4 - 05 5MT Wagon (Praedet's car) - the main platform to combine all my parts
Car #5 - 05 6mt Sedan (T3hFranz's car) - pulling the motor, turbo, and 6mt out of this car to put into my SWP wagon
Powertrain
IAG Closed deck motor built by Topshelf Performance in Portage, WI on 1/15/16
Manley forged pistons 99.55 + .05 Bore 8:5:1 compression
King Subaru rod bearings
King Subaru main bearings
Subaru 10mm oil pump
ARP 625+ head studs
IAG bore and hone 99.75
GSC P-D S2 Cams 272/272 Bilet
Ported heads (8500 RPM limit)
Killer B oil pan
Killer B oil pick up tube
Killer B oil windage tray
Mishimoto Oil Cooler
2011 STI 6MT Transmission
STI R180 rear diff
Spec.b driveshaft & axles
DCCD Pro
ACT HDSS stage 2 Clutch
Whiteline shifter bushings
TGV Deletes
ID1000 injectors
ID Fuel Rails
Top feed fuel conversion
AEM Fuel pump hardwired
Custom fuel lines ran in parallel
AEM FPR + Gauge
IAG AOS
Turbo/Intake/Exhaust/Cooling
Rotate EFR 7163 .85 A/R
AVO FMIC
Tigwerks Twinscroll EL Headers
Tigwerks Twinscroll Up pipe
Tigwerks Twinscroll Downpipe
Magnaflow CBE
STI Red Intake Manifold
TGV Deletes
AEM 4 port EBCS
AEM Intake
Koyo Radiator
Samco Radiator hoses
Samco Boost lines
Suspension
Ohlin 7k/7k Coilovers
Cusco Sway bars
Cusco Underbody braces
Cusco Front strut tower brace
Wilwood 6pot/4pot front/rear brakes
STI Brake booster
Grimmspeed MBC Brace
Spec.b front & rear control arms
Whiteline Pitch Stop
Whiteline steering bushings
Worx Rear Sway Bar Bracket
MSI Front/Rear Endlinks
SuperPro control arm bushings
Group N Motor Mounts
Group N Transmission Mount
SSR 17x9 w/ Continental slicks (track days)
Gun Metal Rota Boost 17x8"/Goodyear Ultra Grip Ice WRT 225/45R17XL (snow days)
Enkei 18x8 w/ Falkien all seasons (winter days)
SSR 18x8.5 w/ Neova AD08 (summer fun drive days)
Work Emotion w/ Falkien summers (summer DD days)
Audio
Alpine HU
ID 10” sub
SEAS components fronts
Polk coax rears
DLS A4 and A5 Amps
Exterior:
35% Tint All around
Clear Bra
Debadge
EDM Rain Guards
Retrofitted HID Projector (BMW)
3000K H3 HID Fog Lights
OEM Mudflaps
Rally Armour UR Mudflaps
Rallitek SSI Stainless Skid Plate
RBS SWP Grill
Subaru OEM Trailer Hitch
Edited by wpmarky
One of these 48......SWP.....2005 Legacy GT wagon MT Ltd (blk)and your going to do what to it...
At least its in good hands.
The other comment is, some people have way to much time on there hands...I'm jealous. LOL
Oh dear, the hack happened to the dashboard ?
Engine Build - Click Here
Yup the SWP 5mt wagon has been my unicorn, will try to treat it well.
Full time job + weekend side business + 2 kids (1yo & 3yo) + wifey = not much time =\ most of the work will be done at midnight after kids & wifey are sleeping, or on a weekend afternoon while visiting the grandparents xD
re: the dash - a dog got to it xD Forgot to add " replace dash" to my list.
Edited by wpmarky
Adding pics so this thread isn't worthless:
1) Ohlin coils vs RCE t1 coils. Nice to have independent height adjustment again.
2) Alcon 6pot vs Brembo 4 pot (caliper just hanging for the pic, supported it better after:lol:)
3) Rear LGT rotor vs alcon front , Brembo front rotor vs Alcon 370mm front rotor, LGT front rotor vs Brembo front rotor.
if you ever decide to replace that hta68, I'll take it. Been looking for another one as I liked mine so much.
looking forward to see this build...
Maybe when I go rotated after going 6mt? :spin:
My initial thoughts on the hta68 vs my old 18g - I like how the 68 feels a bit more linear. Both turbos happened to be tuned by Shamar (Infamous) years ago so that gives it abit more fair comparison.
From what I remember of the 18g on my spec.b is that it had more of a hit when the boost came on at 3500. The hta68 feels more progressively increasing, at least for my 4th gear freeway passing pull on CA91. Haven't tried the hta68 on the e85 tune yet, maybe next week after I finish with the CA registration stuff. I think the current tune is injector limited with 850's. I'd be curious to see the difference after adding in ID1000's.
Will try to dissect the old upper spec.b rear seat's alcantara and insert it into the wagon rear seats.
If that doesn't work, I'll just buy some alcantara to add in. I may need to do that (buy alcantara) anyways for the door inserts since no one sells door cards by themselves. Except for the guy I bought the seats from =\
Here's some inspiration for the backseat:
Looking forward to following your progress with the car!
Edited by LegacyKid5
Looks so good, thanks!
The front seat swap wouldn't have been so bad if I knew you didn't have to take the leather off the foam =\ I literally sewed it back on using zip ties to replace the staple clip things.
My front spec.b seats and rear bottom are currently in the old wagon, will try to swap them in this week.
Where again did you get your alcantara?
Yeah, I picked up a new driver seat bottom cover and I am not at all looking forward to replacing it.
And I had the back seat completely reupholstered at a lock shop. From what he told me, who knows if it's true, there is only one source for real alcantara in the states but he didn't mention the name.
Nice build thread, subbed as I can't wait for this one, sounds like you have enough parts to build two wagons, just keep one to haul around wife & kids, and one for just you.
#LGTSTi is still cheaper and nicer then an equal year wrxsti
Follow my 2007 Spec B. Build here
Sub'd for unicorn porn. Congrats on the find. What wagon owner can say in his heart that he didn't want a white one? Know I did. Looking forward to progress reports and trying to spot it in the wild.
It used to be Gulf Fabrics (http://www.gulffabrics.com/alcanta.htm) that were authorized Toray distributors. It looks like these guys can source it too, https://www.jpmsupplyco.com/collections/alcantara.
  • 1 year later...
Bump from the dead - just bought a friend's car after he totaled it at the track, so that means this wagon's getting some upgrades!
Here's what's on going on soon:
STI 6MT swap w/ DCCD
Closed deck IAG motor w/ Manley pistons and 272 cams
EFR Twin Scroll 7163 turbo w/ IWG and EL headers
Wilwood 6/4 piston F/R brakes
SSR wheels w/ continental slicks (not sure tire specs yet)
Can't wait to hit the track with these new bits. Totally gonna keep the carseats in the back during track day, just for added sleeper effect in the parking lot.
