jumper Posted May 31, 2017 Share Posted May 31, 2017 Hi Guys, My 2005 Jdm Legacy wagon VF38 twin scroll turbo just went. Can you advise me where i can get a replacement or up grade. Also would it be possible to change from twin scroll turbo and what would be required to do so. Thanks:confused: Link to comment Share on other sites More sharing options...
Max Capacity Posted May 31, 2017 Share Posted May 31, 2017 Read the sticky's at the tops of the forum. There's one about turbo wiki. We need to know that your turbo did not put metal pieces into the oil system, that's a common thing. If the engine is not cleaned or rebuilt, you have a very good chance of taking out the new turbo. This in not as easy as you may think...or cheap. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Andy_Mac Posted June 1, 2017 Share Posted June 1, 2017 Where abouts are you located? 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
jumper Posted June 1, 2017 Author Share Posted June 1, 2017 Where abouts are you located? I am in Barbados(Caribbean) Link to comment Share on other sites More sharing options...
jumper Posted June 1, 2017 Author Share Posted June 1, 2017 Read the sticky's at the tops of the forum. There's one about turbo wiki. We need to know that your turbo did not put metal pieces into the oil system, that's a common thing. If the engine is not cleaned or rebuilt, you have a very good chance of taking out the new turbo. This in not as easy as you may think...or cheap. I have read the turbo wiki and i am aware of all issues associated with it, as well as cost. Just need to know where i can get the turbo. Thanks. Link to comment Share on other sites More sharing options...
oODanKNesSOo Posted June 1, 2017 Share Posted June 1, 2017 Moar powa!!! JMP may be able to rebuild your blown snail shell, and being it out... If bit were me I'd reach out to him. He is a forum Legend Link to comment Share on other sites More sharing options...
