slvrlegacygt Posted May 10, 2017 Share Posted May 10, 2017 I have an 07 Spec B with 163,xxx miles on the original clutch. It is starting to slip. I am currently at stage 2.5 I was going to add some more power to the car. I am looking at getting an exedy stage 1 HD clutch. Should I keep the original flywheel or get a new flywheel when I change the clutch? Is there any benefit to getting an sti flywheel? I also do not want to go with a lighter flywheel. What else would I need for swapping out the clutch? As in bits and pieces you don't realize you would need until actually doing the install. this is what I am looking at http://shop.exedyusa.com/exedy-racing-clutch/exedy-racing-stage-1-organic-clutch-kit/g-50052.aspx?aid=9261556 Link to comment Share on other sites More sharing options...
Max Capacity Posted May 10, 2017 Share Posted May 10, 2017 From what I've learned if your going to use a STI FW you need a complete STI clutch kit. For some reason the parts are different. Look in the "opposedforces" thread at the top of the very first forum. I ended up with a OEM clutch kit. I had my FW turned and re-used it. Read this thread, http://legacygt.com/forums/showthread.php/spec-b-6mt-throw-out-bearing-261306.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
slvrlegacygt Posted May 10, 2017 Author Share Posted May 10, 2017 i actually just edited what I was looking to do. I wasn't looking at the stage 2 clutch kit. I was looking for the stage 1 hd kit. It says to install with their lightweight flywheel. If am looking for an sti kit what model years should I be looking for? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 10, 2017 Share Posted May 10, 2017 I think in those links its like a 05-14 STI could even be a 05-17. You may want to contact Mike at http://www.AZPinstals.com his shop is in NJ talk with him or Rey and have them get you what they would use in there car. Tell them I sent you. You will also need Motul gear 300 buy that from them too. I did. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
slvrlegacygt Posted May 10, 2017 Author Share Posted May 10, 2017 I will reach out to them and thank you for helping me out. Link to comment Share on other sites More sharing options...
Lgt005 Posted May 19, 2017 Share Posted May 19, 2017 I would suggest looking into the south bend clutches. I think that is what I will get next time I need a clutch. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 23, 2017 Share Posted May 23, 2017 I would suggest looking into the south bend clutches. I think that is what I will get next time I need a clutch. For a Spec B, you better call the clutch company and talk to someone. Spec B's have a different clutch kit then STi's or GT's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
l88m22vette Posted May 26, 2017 Share Posted May 26, 2017 Honestly, just keep it simple and get all STi parts, it has a larger clutch disc (so more holding power), there are a thousand options, and its easier and cheaper to find an STi flywheel, clutch/PP, etc. Link to comment Share on other sites More sharing options...
d22597 Posted May 27, 2017 Share Posted May 27, 2017 FWIW I just had someone install an ACT HDSS (SB10-HDSS) with ACT flywheel (600235) on my 09 specb. Wasn't my first choice, but it was what the shop recommended and backed. Still breaking it in, but my first impression is positive. It is noticeably heavier than stock, but no shudder and engagement is starting to smooth out. I was concerned at first because engagement was initially immediate and shallow. It took about 50 miles to start getting more peddle and normal engagement. I'm only at 150 miles now. Link to comment Share on other sites More sharing options...
