abstract_alchemy Posted April 27, 2017 Share Posted April 27, 2017 I didn't realise I had a pinhole leak in my trans cooler line. I ran my Legacy too low on trans fluid and couldn't shift out of park in a taco bell drive thru. I was able to get it out of park with some help from the guys behind me. I made it to a gas station and immediately put in transmission fluid. It took over a quart. How F#<{3D am I? Link to comment Share on other sites More sharing options...
Setnev Posted April 27, 2017 Share Posted April 27, 2017 Fix the leak and refill the fluid. Chances are the transmission is fine. The transmission has clutches that engage by fluid. Coincidentally, the fluid also keeps the clutches from burning up, but it doesn't sound like you drove it very long with it low. Link to comment Share on other sites More sharing options...
Brighton96 Posted April 27, 2017 Share Posted April 27, 2017 Yeah, only a quart low for a short period would not be good, but it shouldn't be enough to kill the trans. Link to comment Share on other sites More sharing options...
doublechaz Posted April 29, 2017 Share Posted April 29, 2017 If it gets low enough to suck air into the pump pickup it might fail to clamp fully on the clutches and it could slip and really wear the clutches. But I think you would have noticed that if that happened. There is some headroom in fluid level. I doubt you did any damage. Link to comment Share on other sites More sharing options...
