legacylee Posted April 22, 2017 Share Posted April 22, 2017 looks like we'll be shopping for heads for our rebuild. just picked the heads up from the garage to take to the machine shop. there is slight galling in the journals,any suggestions? I've been reading A LOT but not having any luck. I've been trying to research the vendors also but, with helping my kid move, and life itself i need help. I live near Rochester NY any help would be greatly appreciated Lee Link to comment Share on other sites More sharing options...
Max Capacity Posted April 22, 2017 Share Posted April 22, 2017 member HAMMERDOWN is near you PM him and see if knows anything that may be of help. The machine shop will be able to tell you if the heads are ok to use. this thread may help, http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html http://www.car-part.com for junkyard heads. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Th3Franz Posted April 22, 2017 Share Posted April 22, 2017 how deep are the journals scored? Can a scotchbrite pad clear them up? This one was donezo and had to be replaced. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
legacylee Posted April 24, 2017 Author Share Posted April 24, 2017 OK so i just came from the machine shop. It looks like i will definitely need the right head. I did get some leads from the shop , so i will be pursuing these for head possibilities. ill keep my fingers crossed. Link to comment Share on other sites More sharing options...
