friedkin Posted April 17, 2017 Share Posted April 17, 2017 I cant find any info and picture where egr valve is placed? can someone tell me or show the place of the piece on the picture? http://i.hizliresim.com/1LBmvj.jpg Link to comment Share on other sites More sharing options...
Brighton96 Posted April 17, 2017 Share Posted April 17, 2017 Looks like your car doesn't have one. It is normally found attached to the intake manifold on the drivers side rear section (closest to the brake master cylinder) Manual cars and certain others don't have EGR systems Link to comment Share on other sites More sharing options...
Setnev Posted April 17, 2017 Share Posted April 17, 2017 Should be right here where the circled area is, but it appears it's not there. http://i.imgur.com/XwrnFHl.png Refer to my engine shot and the red circled area: http://i.imgur.com/He67rqe.png Link to comment Share on other sites More sharing options...
Brighton96 Posted April 17, 2017 Share Posted April 17, 2017 Correct, your car either has a Non EGR intake or just didn't come with it factory Link to comment Share on other sites More sharing options...
Setnev Posted April 17, 2017 Share Posted April 17, 2017 Guessing by the design of the intake tube, it looks to be either a 95 or 96 with the 2.2L. If I had to guess, it's an early 95 Brighton with the EJ22 with an automatic transmission. I don't see the clutch cable and the absence of cruise control indicates a Brighton. Link to comment Share on other sites More sharing options...
friedkin Posted April 17, 2017 Author Share Posted April 17, 2017 I didnt know some models doesnt have egr.. my car 96 automatic 2.0 engine. Link to comment Share on other sites More sharing options...
Brighton96 Posted April 17, 2017 Share Posted April 17, 2017 Sounds about right, I'm guessing it's not a 96 auto though. Mines an early build year 96 Brighton with an auto and I have an EGR. If you're really curious, just check the date on the inside of the oil cap. That'll tell you the build time of the motor. Link to comment Share on other sites More sharing options...
friedkin Posted April 18, 2017 Author Share Posted April 18, 2017 haha... no egr, no problem, isnt it? Link to comment Share on other sites More sharing options...
Brighton96 Posted April 18, 2017 Share Posted April 18, 2017 Yep, it's just an emissions thing that only really gets used at highway cruising speed. Link to comment Share on other sites More sharing options...
Setnev Posted April 18, 2017 Share Posted April 18, 2017 I didnt know some models doesnt have egr.. my car 96 automatic 2.0 engine. JDM 2.0 swap? Link to comment Share on other sites More sharing options...
Brighton96 Posted April 18, 2017 Share Posted April 18, 2017 That would explain the odd looking powersteering reservoir. On the block just under the back left of the alternator is a stamp that'll say EJ20, EJ2, EJ25 Link to comment Share on other sites More sharing options...
choover1101 Posted April 18, 2017 Share Posted April 18, 2017 Just curious, why are you looking for the EGR? Are you throwing a code (check engine light)? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
friedkin Posted April 19, 2017 Author Share Posted April 19, 2017 Just curious, why are you looking for the EGR? Are you throwing a code (check engine light)? Sent from my iPhone using Tapatalk No, there have no problem curently, sometimes the egr valve needs to be cancelled or cleaned for more performance... Link to comment Share on other sites More sharing options...
friedkin Posted April 19, 2017 Author Share Posted April 19, 2017 JDM 2.0 swap? sorry I dont understand exact what mean "JDM 2.0 swap?" brigton96, motor code is EJ20E its write on chasis plate... Link to comment Share on other sites More sharing options...
Setnev Posted April 22, 2017 Share Posted April 22, 2017 sorry I dont understand exact what mean "JDM 2.0 swap?" brigton96, motor code is EJ20E its write on chasis plate... What is your location? EJ20E is a JDM motor and if your car shows that on the chassis plate, you either aren't in the US, or of you are, it was an imported RHD Legacy Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
friedkin Posted April 23, 2017 Author Share Posted April 23, 2017 What is your location? EJ20E is a JDM motor and if your car shows that on the chassis plate, you either aren't in the US, or of you are, it was an imported RHD Legacy Sent from my SM-N920V using Tapatalk Yes I'm in Turkey... Link to comment Share on other sites More sharing options...
Setnev Posted April 24, 2017 Share Posted April 24, 2017 No, there have no problem curently, sometimes the egr valve needs to be cancelled or cleaned for more performance... With no EGR, no worries on having to do any of that. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
