friedkin Posted April 13, 2017 Share Posted April 13, 2017 can I adjust 96 legacy idle rpm? Link to comment Share on other sites More sharing options...
twisty Posted April 13, 2017 Share Posted April 13, 2017 no, there is an IACV involved, i dont think i would change any of the adjuster screws. most of the time, if the idle is erratic or off, there is another reason causing the computer to change it. what are the symptoms youre seeing? Link to comment Share on other sites More sharing options...
Brighton96 Posted April 13, 2017 Share Posted April 13, 2017 Yes you can adjust it, there is a threaded stud with a nut on the , its on the driver side of the throttle body by the throttle cable, you just need to loosen the nut and then tighten the stud so that it moves closer to the throttle cable bracket, then once its where you're happy, just tighten the nut to lock it all in place. Link to comment Share on other sites More sharing options...
twisty Posted April 13, 2017 Share Posted April 13, 2017 but why should it need adjusted, is my point. the ecu does a fairly good job at controlling it as it sits, unless it was changed before without reason. Link to comment Share on other sites More sharing options...
Brighton96 Posted April 13, 2017 Share Posted April 13, 2017 I sped mine up since it had a lumpy idle caused by a tight valve. It would idle like crap at 800ish and would frequently try to stall out, so I sped mine up to 1200-1300 and that smoothed it out a lot. Now that the junk head is no longer on the motor, I slowed it back down to normal Link to comment Share on other sites More sharing options...
friedkin Posted April 13, 2017 Author Share Posted April 13, 2017 I've tried before adjusting the throttle cable that you mention about but idle rpm always returned to old position after a while, I dont know why, vehicles idle rpm is about to 600-700 when its neutral position, when I change the gear neutral to drive, the value is falling about to 300-400, isnt that too much? It seems like the car stopped during this time, when I've adjusting idle rpm with throttle cable method, It is going to be very convenient for a while, until the idle rpm down to the old value. The whole problem seems to be solve if I can raise idle rprm some, but permanently... Can it be adjusted with the help of a computer connection? Is not this the screw you mentioned? http://i.hizliresim.com/W0p6r2.jpg Link to comment Share on other sites More sharing options...
Brighton96 Posted April 13, 2017 Share Posted April 13, 2017 No that's not it, its down lower on the throttle body, maybe an inch or two below the throttle spring/bracket set up. It's easier to see it if you look at it from the other side. Link to comment Share on other sites More sharing options...
friedkin Posted April 13, 2017 Author Share Posted April 13, 2017 brighton96 thaks for your help but I really dont understand where is that thing ??? It would be great if there was a picture ... Link to comment Share on other sites More sharing options...
Brighton96 Posted April 13, 2017 Share Posted April 13, 2017 I'll get a picture here shortly cause it's not easy to explain it haha Link to comment Share on other sites More sharing options...
choover1101 Posted April 13, 2017 Share Posted April 13, 2017 This one? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
friedkin Posted April 13, 2017 Author Share Posted April 13, 2017 I wonder if it can be that part? this is idle air control valve and maybe we must losen that 2 screws and turn that upper part one way??? http://i.hizliresim.com/V0zLmB.jpg Link to comment Share on other sites More sharing options...
Brighton96 Posted April 13, 2017 Share Posted April 13, 2017 Choover got it and posted it too fast haha! Don't mess with the IACV, just use an 8mm? and a flat head screw driver to adjust the idle Link to comment Share on other sites More sharing options...
friedkin Posted April 13, 2017 Author Share Posted April 13, 2017 ok thanks... I will try as soon as possible... Link to comment Share on other sites More sharing options...
friedkin Posted April 14, 2017 Author Share Posted April 14, 2017 I've increase idle rpm little bit today and everything seems ok for now, vehicle is being more agile and shifting more smoother... thanks everybody... especially brighton96... Link to comment Share on other sites More sharing options...
