Siriya Posted February 26, 2017 Share Posted February 26, 2017 Guys, Anyone know where i can get the rebuild kit for this pump ? The item number i should look for if possible. Thanks. ---- 2005 Legacy JDM Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted February 27, 2017 Share Posted February 27, 2017 Dealer Dealer Dealer, for oem quality gaskets and seals, only buy subaru branded, or it will leak again 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
bluesuby Posted February 27, 2017 Share Posted February 27, 2017 If I remember correctly, the leak usually is fixed by replacing an o-ring available at the dealer for a couple dollars. Try a search and view the pictures. Easy job. Link to comment Share on other sites More sharing options...
Siriya Posted February 27, 2017 Author Share Posted February 27, 2017 Thanks gents! Link to comment Share on other sites More sharing options...
ATLspeed Posted April 19, 2017 Share Posted April 19, 2017 Bumping this up. Is there an actual rebuild kit for these powersteering pumps from Subaru? Gave them a call and they say no. So what is everyone using? Not looking to buy a new/reman'd pump for $200+/-. Link to comment Share on other sites More sharing options...
relative4 Posted April 19, 2017 Share Posted April 19, 2017 There is no rebuild kit. Search this forum and you'll find a guy who did a rebuild with photos and specs of all the O-rings, etc. he acquired in the process. FWIW, often the suction hose cracks where it meets the pump and makes it look like the pump is leaking. Link to comment Share on other sites More sharing options...
Siriya Posted April 21, 2017 Author Share Posted April 21, 2017 Apparently a known (and should be expected at some point) failure is that of the o-ring for the PS pump. Its easily resolved by a $3 o-ring from the dealer as mentioned by the gurus above. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 21, 2017 Share Posted April 21, 2017 FWIW, you can find the parts from one of these sites, http://legacygt.com/forums/showthread.php/oem-online-subaru-parts-vendors-list-42243.html or http://legacygt.com/forums/showthread.php/subaru-oem-parts-catalog-online-exploded-views-opposed-forces-130411.html or http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html or http://people.csail.mit.edu/ilh/vacation/ lately I've found this site to be very easy to use, http://estore.subarupartswarehouse.com/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
