Beamercub Posted February 20, 2017 Share Posted February 20, 2017 Was worried about disconnecting the negative battery cable/ will I need a code to activate the radio or satellite? Fingers crossed that when I reconnect the battery, nothing will be changed or need adjusting... -Memory seat buttons? Link to comment Share on other sites More sharing options...
upstater Posted February 20, 2017 Share Posted February 20, 2017 Was worried about disconnecting the negative battery cable/ will I need a code to activate the radio or satellite? Fingers crossed that when I reconnect the battery, nothing will be changed or need adjusting... -Memory seat buttons? your power window one touch will need to be recalibrated, no need to disconnect the battery for HID bulbs, I am alive, and shock free. Turn headlight stalk off (not on auto setting) and don't open the door. Keep car powered off. You will be fine. Problem would be if you are messing with HID wiring, someone opens car door, ambient light is bad in garage, Auto sensors turn on headlights because you left them in Auto, and there ya go, zing. Link to comment Share on other sites More sharing options...
chowser51 Posted February 20, 2017 Share Posted February 20, 2017 I hooked up a portable power supply to my obdii port when I disconnected my battery to clean it and didn't lose any of my settings. Link to comment Share on other sites More sharing options...
BeastCoast Posted February 20, 2017 Share Posted February 20, 2017 You wont lose any settings. Just your clock. Power windows don't even need to be recalibrated. I have unhooked my battery probably 15 times and everytime, the auto windows stop working for a little bit but start workign again on their own. @BeastCoast1 Link to comment Share on other sites More sharing options...
