taylormac1993 Posted February 11, 2017 Share Posted February 11, 2017 All my lights are out. Headlights, foglights, running lights, dash lights, you name it. The parking lights on top of the steering column work, as do the hazards, turn signals, and high beams (only momentary switch works. Pushing the switch forward does nothing). Brake lights also work. This happened when I was trying to troubleshoot a headlight issue and bridged a wire in place of one of the HL relays. I figured it was a fuse but all fuses are good, including the stupid big ones. Checked most of the applicable relays by switching them with AC relays (same part) and nothing makes a difference. I am down to jiggling the switch around to see if that works but nothing happens no matter what I do. The car does run thankfully, and I havent noticed it throw any new CELs, not that I could check them anyway Link to comment Share on other sites More sharing options...
Brighton96 Posted February 11, 2017 Share Posted February 11, 2017 Maybe illumination unit? It's just a box attached to the panel under the steering wheel Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 12, 2017 Author Share Posted February 12, 2017 You happen to have a pic? I was at a junkyard tearing some apart today and didnt see anything like that. Link to comment Share on other sites More sharing options...
Brighton96 Posted February 12, 2017 Share Posted February 12, 2017 I don't have a picture but here's an ebay listing, the "illumi con unit" is missing from this kick panel but it is normally mounted to the right of where the other things are mounted, where there is a single mounting hole. I used to have a spare illumi unit but I guess I lost it :/ This is what the unit looks like http://ebay.am-autoteile.de/ImageGallery/images/665a350a-971b-4402-bbf8-a38933664250/large.jpeg And here is the listing http://www.ebay.com/itm/96-99-SUBARU-LEGACY-OUTBACK-UNDER-STEERING-COLUMN-LOWER-DASH-KICK-PANEL-/291856176081?fits=Year%3A1998%7CMake%3ASubaru%7CModel%3ALegacy&hash=item43f3fbd3d1:g:hzEAAOSwV0RXv4gK&vxp=mtr Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 12, 2017 Author Share Posted February 12, 2017 I found mine. Is there a way to test these? The two bgs at the junkyard here didnt have these. Link to comment Share on other sites More sharing options...
Brighton96 Posted February 12, 2017 Share Posted February 12, 2017 I mean, I'm sure there is a way to get a multimeter and check if it works but you'd have to find the pin diagram for it. I would just plug the new one into the car and see if works. Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 12, 2017 Author Share Posted February 12, 2017 Thats the problem, I didnt find one. I only have the stock one Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 12, 2017 Author Share Posted February 12, 2017 Im about to go get every one I can find from a scrap yard today. We will see if it fixes it but I still have a weird wiring issue I believe. More updates to come. Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 12, 2017 Author Share Posted February 12, 2017 I got three modules from a scrap yard and none of them make a difference. Could it be the switch? Link to comment Share on other sites More sharing options...
Brighton96 Posted February 13, 2017 Share Posted February 13, 2017 Oh I was sure that was it :/ And I mean it COULD be the switch but I really doubt it, Do the wipers and windshield sprayers work? If they still work then I'd say it's not the switch. Link to comment Share on other sites More sharing options...
doublechaz Posted February 13, 2017 Share Posted February 13, 2017 Was there any sparking when you were bridging that relay? Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 13, 2017 Author Share Posted February 13, 2017 I didnt see any sparks. Its possible it shorted the switch though. I figured it would blow the fuse but I have no idea what happened. Wipers and everything work I just have no headlights or running lights. Im about to swap a different ecm over and see if that has any effect on it. I have a spare laying around so why not right? If that fails I will have to see if its this switch... that involves taking the damn steering wheel off. :/ Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 13, 2017 Author Share Posted February 13, 2017 And as expected it didnt change a damn thing. I guess im pulling the wheel. Link to comment Share on other sites More sharing options...
Brighton96 Posted February 13, 2017 Share Posted February 13, 2017 I mean, pulling the wheel isn't too bad. The hardest part is just breaking the wheel loose of the spined shaft. Just hammer fist it a few times, pretty painless. Link to comment Share on other sites More sharing options...
doublechaz Posted February 13, 2017 Share Posted February 13, 2017 Can't you get to the connector for the switch without pulling the wheel? Then you can check for continuity on the pins per the FSM. I know I checked my ignition switch that way once. Just pull a couple trim bits. Link to comment Share on other sites More sharing options...
Brighton96 Posted February 13, 2017 Share Posted February 13, 2017 If you remove the plastic around the steering column you can get access to the switch and you may be able to disconnect it to test it. Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 15, 2017 Author Share Posted February 15, 2017 It turned out to be the headlight switch. A few hours and $16 later I got a used one installed and it's back to normal. Link to comment Share on other sites More sharing options...
doublechaz Posted February 15, 2017 Share Posted February 15, 2017 Today sounds to have been very successful for forum members. That's good news. Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 15, 2017 Author Share Posted February 15, 2017 By back to normal I mean Im still having bad issues with wiring but at least now I can troubleshoot it. My low beams are very dim using both fillaments and my high beams are actually my low beams. Ive quadruple checked both sides and I have it wired right. Any ideas on that? Link to comment Share on other sites More sharing options...
Das Ninjabot Posted February 15, 2017 Share Posted February 15, 2017 That sounds like it could be a bad ground issue. Link to comment Share on other sites More sharing options...
Brighton96 Posted February 15, 2017 Share Posted February 15, 2017 +1 for bad/loose grounds Link to comment Share on other sites More sharing options...
taylormac1993 Posted February 16, 2017 Author Share Posted February 16, 2017 Thats what everyone says but my ground wires to the headlight pigtail show zero resistance. I should check the grounds to the relays and the illumination control module too. Any other ideas on what to check? Link to comment Share on other sites More sharing options...
Brighton96 Posted February 16, 2017 Share Posted February 16, 2017 Id check the grounds under the dash/on the trans tunnel and then I would also check the grounds on either frame rail under the hood. Link to comment Share on other sites More sharing options...
doublechaz Posted February 16, 2017 Share Posted February 16, 2017 You could also do some involved testing of ohms through the relays when they are energized. That would involve disconnecting some stuff, so I'd leave that until you've exhausted other tests. Link to comment Share on other sites More sharing options...
