1-3-2-4 Posted February 9, 2017 Share Posted February 9, 2017 Does anyone know what the ID of the fuel hose is? stupid me was following something on another site and I ordered the hose and it's 3/8" ID and it's way too huge.. it's the two rubber hoses for the metal fuel lines and the one on the right side of the hard lines. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 9, 2017 I Donated Too Share Posted February 9, 2017 I believe it must be 2.5/8" - also known as 5/16" - at least that's what I have been using. I purchased Russell 640863 5/16" SAE Quick-Disconnect Female Push-On EFI fittings too when I went to -6 AN and prior to that I was using EFI rated 5/16" fuel hose when I was messing about with the sti regulator. Be careful messing about with your fuel system. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 9, 2017 Author Share Posted February 9, 2017 I believe it must be 2.5/8" - also known as 5/16" - at least that's what I have been using. I purchased Russell 640863 5/16" SAE Quick-Disconnect Female Push-On EFI fittings too when I went to -6 AN and prior to that I was using EFI rated 5/16" fuel hose when I was messing about with the sti regulator. Be careful messing about with your fuel system.Yeah that's why I'm going to change the old 10+ year old rubber hoses. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2017 Share Posted February 9, 2017 Take the pipe and go to the auto parts store like NAPA, they will have the right hose. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 9, 2017 I Donated Too Share Posted February 9, 2017 Is it broke? You have a problem with the old ones? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 9, 2017 Author Share Posted February 9, 2017 It's brittle and it's over 10 years old Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2017 Share Posted February 9, 2017 My local NAPA has a selection of hoses just to the left of the counter, easy to find what you need. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
chhrisd Posted February 9, 2017 Share Posted February 9, 2017 It's 5/16" (8mm). Make sure you are buying fuel injection hose, not PCV hose or carb hose. The hose itself should be labeled for the application. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2017 Share Posted February 9, 2017 ^ good point...but by this day and age, I would hope people like him realize that, but its always good to mention it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 9, 2017 I Donated Too Share Posted February 9, 2017 If it ain't broke fix it until it is. Be careful with the fittings - If you're hell bent on this, why not get OEM replacement hoses so you can be sure they are all good and sealed properly? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 9, 2017 Author Share Posted February 9, 2017 If it ain't broke fix it until it is. Be careful with the fittings - If you're hell bent on this, why not get OEM replacement hoses so you can be sure they are all good and sealed properly? Because it's $18 for one hose Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
08SpecB_DE Posted February 10, 2017 Share Posted February 10, 2017 Those fuel lines are not a big deal to replace. Be sure to only use fuel injection hose clamps and I'd recommend getting new ones. Advance sells them and should have them in stock. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 11, 2017 Author Share Posted February 11, 2017 Picked up the hose at advance auto they had some already bagged and on the shelf in one of the aisles 18" was enough to do all 3 hoses picked up new clamps as well. Link to comment Share on other sites More sharing options...
