Beamercub Posted February 2, 2017 Share Posted February 2, 2017 The bulb for directional and DRL in one? Link to comment Share on other sites More sharing options...
PATS4LIFE Posted February 2, 2017 Share Posted February 2, 2017 No turn signal is separate But the high beam and DRL are one Link to comment Share on other sites More sharing options...
CT2015Legacy Posted February 2, 2017 Share Posted February 2, 2017 You won't be able to use switchback bulbs in the Legacy unless you use some type of resistors and tap into the OEM wiring as the relay is actually build into the control module for the vehicle and cannot be removed like it can on previous generations and current model Forester, Impreza, WRX/STI, etc. Link to comment Share on other sites More sharing options...
1692 Posted February 6, 2017 Share Posted February 6, 2017 There are multiple threads that talk about the ones you can order plus how to install them. http://legacygt.com/forums/showthread.php/huge-thanks-ttg-and-power-community-255458.html?t=255458&highlight=led+drl http://legacygt.com/forums/showthread.php/7440-7443-switchback-led-vs-v3-triton-switchbacks-drl-255402.html?t=255402&highlight=switchback http://legacygt.com/forums/showthread.php/v3-triton-switchbacks-drl-245657.html?t=245657&highlight=switchback Link to comment Share on other sites More sharing options...
