michigansubie Posted January 31, 2017 Share Posted January 31, 2017 Hi all, I have a 2005 LGT. The other day, under just normal driving conditions, when i have it in second gear (MT), there is a loud constant knocking sound while driving, but it does not happen while in any other gear. I can feel the knock if i have my hand on the shifter. Clutch feels normal, and it is not hard to get into 2nd gear, just knocks very loud. What could this be? Broken tooth? Old synchros? I have 176XXX miles. Thanks! Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 31, 2017 I Donated Too Share Posted January 31, 2017 I was going to say worn CV joints banging but only 2nd gear. If that's true, for sure, for real... and you can only get the knocking when in 2nd gear then you have isolated the issue and it's time to drain that gearbox fluid and pan it like you're looking for gold. If you see horrible things then that gearbox needs to come down. Link to comment Share on other sites More sharing options...
michigansubie Posted February 1, 2017 Author Share Posted February 1, 2017 Update happens now in all gears, and makes a slow knocking noise sitting in neutral, but 2nd gear is still the worst. Sent from my SM-G920T using Tapatalk Link to comment Share on other sites More sharing options...
JustCallMeNick Posted February 2, 2017 Share Posted February 2, 2017 Update happens now in all gears, and makes a slow knocking noise sitting in neutral, but 2nd gear is still the worst. Sent from my SM-G920T using Tapatalk It's making a knocking sound in neutral when you're not moving? Or in neutral when the car is rolling? EDIT: I now see that you said "sitting in neutral." I would not drive that car anymore. Have it flat-bedded to a good shop. What part of Michigan are you in? (Nice to see another Michigan Legacy) Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 2, 2017 I Donated Too Share Posted February 2, 2017 (Nice to see another Michigan Legacy) Not for long apparently... Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 2, 2017 Share Posted February 2, 2017 Absolutely sounds like transmission has reached the end of it's lifespan. I would begin the look for a new one and park the car before it leaves you stranded. Link to comment Share on other sites More sharing options...
JustCallMeNick Posted February 2, 2017 Share Posted February 2, 2017 Not for long apparently... Link to comment Share on other sites More sharing options...
