JMJ5150 Posted January 23, 2017 Share Posted January 23, 2017 Anyone know if a 2008 JDM/EDM Legacy fender will fit USDM bumper & headlights? Link to comment Share on other sites More sharing options...
Underdog Posted January 23, 2017 Share Posted January 23, 2017 It will not. The little turn-up detail at the bottom outer corner of the headlights is further aft on USDM cars. The Crimson Dynamo Link to comment Share on other sites More sharing options...
JMJ5150 Posted January 24, 2017 Author Share Posted January 24, 2017 It will not. The little turn-up detail at the bottom outer corner of the headlights is further aft on USDM cars. So I will need a JDM conversion with headlights or can it be modified? http://image.dhgate.com/aktdesc_1052303274_00.jpg Link to comment Share on other sites More sharing options...
Underdog Posted January 24, 2017 Share Posted January 24, 2017 I dont see why it couldn't be modified but I'm sure it would be less expensive and cleaner to do the swap properly. The Crimson Dynamo Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 25, 2017 Share Posted January 25, 2017 Underdog, how about fitting an EDM/JDM 2005 front subaru outback bumper to a 2005 USDM subaru outback? Would it fit without any mods to fenders and stuff like that? As far as I can tell, the only mod needed may be to take out the foam off the bumper beam. sorry to hijack http://i.ebayimg.com/images/g/cuEAAOSwo4pYK0cx/s-l1600.jpg Link to comment Share on other sites More sharing options...
Underdog Posted January 25, 2017 Share Posted January 25, 2017 The rev.A-C LGT and OBXT bumpers are interchangeable as far as headlights and grille are concerned. The Crimson Dynamo Link to comment Share on other sites More sharing options...
WRX USA Posted January 25, 2017 Share Posted January 25, 2017 So I will need a JDM conversion with headlights or can it be modified? http://image.dhgate.com/aktdesc_1052303274_00.jpg I'm sure it could but it would be costly to be done right and then if anything happens you'll need another one custom made. Switching over to all JDM (except USDM hood, since it works) give you lots of options with fenders, front bumpers, and grilles. Link to comment Share on other sites More sharing options...
WRX USA Posted January 25, 2017 Share Posted January 25, 2017 Underdog, how about fitting an EDM/JDM 2005 front subaru outback bumper to a 2005 USDM subaru outback? Would it fit without any mods to fenders and stuff like that? As far as I can tell, the only mod needed may be to take out the foam off the bumper beam. sorry to hijack Front bumper, on a preface Outback or Legacy, should be a straight swap between USDM and JDM (except the foam absorber, if you are using a USDM front beam). Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 25, 2017 Share Posted January 25, 2017 ^That's what i figured. Link to comment Share on other sites More sharing options...
JMJ5150 Posted January 26, 2017 Author Share Posted January 26, 2017 I'm sure it could but it would be costly to be done right and then if anything happens you'll need another one custom made. Switching over to all JDM (except USDM hood, since it works) give you lots of options with fenders, front bumpers, and grilles. Thank you!!! That clarifies everything for me... I will just need a front bumper and headlights to complete this project.. Which are HARD to find right now at a decent price... Are the headlights a direct swap or will I need something like a new harness? Link to comment Share on other sites More sharing options...
WRX USA Posted January 26, 2017 Share Posted January 26, 2017 Thank you!!! That clarifies everything for me... I will just need a front bumper and headlights to complete this project.. Which are HARD to find right now at a decent price... Are the headlights a direct swap or will I need something like a new harness? I don't know of a harness that could easily be swapped. The wiring on USDM and JDM headlights are different. I ended up modifying my JDM headlights so that I could fit my USDM switchback turn signal. Link to comment Share on other sites More sharing options...
JMJ5150 Posted January 28, 2017 Author Share Posted January 28, 2017 I don't know of a harness that could easily be swapped. The wiring on USDM and JDM headlights are different. I ended up modifying my JDM headlights so that I could fit my USDM switchback turn signal. Thanks for all the help... Would a 08-09 JDM Legacy Outback bumper and fender work? Those years don't seem to have the flares as prior versions. Link to comment Share on other sites More sharing options...
WRX USA Posted January 28, 2017 Share Posted January 28, 2017 Thanks for all the help... Would a 08-09 JDM Legacy Outback bumper and fender work? Those years don't seem to have the flares as prior versions. No, this won't work. The 08-09 JDM Outback fenders don't come with flares but they have the holes for the OEM ones to clip on so you couldn't use them on a Legacy without filling those holes. The JDM bumper also has the flares built in. Link to comment Share on other sites More sharing options...
