MaasaiWarrior Posted January 12, 2017 Share Posted January 12, 2017 Guys, I've had my lgt for 3 years now and have loved every minute of it, but its always have felt like its had a very heavy shift. It's never been super smooth between the gears, I generally have to pause the shift ever so slightly between final points when changing gears. The fluid is in good shape and clear, I did change it about 20k ago, has anyone else had this issue or is it just normal with our cars? 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
MTBwrench Posted January 12, 2017 Share Posted January 12, 2017 Every 5MT I've driven has seemed to sort of 'fight' me if I try shifting too quickly, however never to the point that it was a serious issue. What fluid did you put in last time? From what I've heard the 5MT can be pretty sensitive to fluid types/brands etc. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12, 2017 Share Posted January 12, 2017 Motul gear 300 is what you want to use in the tranny. And Moore Performance Blast Plates will make it shift cleanly every time. I love the blast plates on my 5mt. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted January 19, 2017 Author Share Posted January 19, 2017 I'm not sure on the fluid, well which brand anyway. I did go with the manual specs I remember. Maybe I'll try switching up the fluid to the motul when it warms up a bit here 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Rhitter Posted January 20, 2017 Share Posted January 20, 2017 Guys, I generally have to pause the shift ever so slightly between final points when changing gears. This is a good description of how I shift my 5mt. I think of it as two movements to change gear instead of just one. Pretty annoying when trying to shift quickly at high RPMs. My OBXT build Link to comment Share on other sites More sharing options...
