PurpleSNow Posted January 12, 2017 Share Posted January 12, 2017 I have a 93 legacy with 4speed auto and for some reason it smokes a bunch when i puch it hard or driving over 140kph about 65mph for others. it does have a small oil leak on the sump but why does it smoke so profusely when under heavy load. and when i stop the smoke comes from the engine as well so I imagine it leaks over the manifault as well. what can i look at or should i start with sorting out the sump leak first. it hapened today as well when doing a 3 point u turn in the street and had to do it quick so i suppose it put some more load on the box. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 12, 2017 Share Posted January 12, 2017 Well generally speaking when you are at higher load there is higher pressure so it forces more oil out of the leak than at low pressure. It sounds like your valve cover gaskets spark plug tube seals are bad. I would also have a look at your head gaskets along with the bottom from and rear of your engine. The rear main seal will leak and gunk up the oil pan area and drip on the exhaust the Crank and Cam seal will leak doing the same only in the front of the engine. Link to comment Share on other sites More sharing options...
PurpleSNow Posted January 13, 2017 Author Share Posted January 13, 2017 the smoking is really bad though ans can smell it is atf not motor oil. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 15, 2017 Share Posted January 15, 2017 sounds like it is leaking somewhere, where the trans is close to the exhaust. Link to comment Share on other sites More sharing options...
PurpleSNow Posted January 16, 2017 Author Share Posted January 16, 2017 It might be the power stearing pipe as well since that also takes a beating when turning side to side very fast. will have a look at that tomorrow but still what bothers me is that the car smokes heavily when at high speeds. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 16, 2017 Share Posted January 16, 2017 from the tail pipe or just under the car in general? Link to comment Share on other sites More sharing options...
PurpleSNow Posted January 17, 2017 Author Share Posted January 17, 2017 from under the car and when i stop from the hood as well Link to comment Share on other sites More sharing options...
Osei Posted January 18, 2017 Share Posted January 18, 2017 Weather being cold here (don't know your location), I'd ordinarily suggest cleaning the top of the engine off with degreaser and water to try and narrow down the source. You can clean the pump area with a rag, gas, and carb cleaner. O. Link to comment Share on other sites More sharing options...
PurpleSNow Posted January 24, 2017 Author Share Posted January 24, 2017 ok so now i fixed the leak, was the power steering feed pipe. Now nice new problem. the car has no more drive after about 100 meters. then shut down the car and start it again after a minute then it engages again but only again for about 100m. Can this be a damaged torque converter Link to comment Share on other sites More sharing options...
Osei Posted January 24, 2017 Share Posted January 24, 2017 Level of ATF checked? Can't damage a torque converter. O. Link to comment Share on other sites More sharing options...
PurpleSNow Posted January 25, 2017 Author Share Posted January 25, 2017 atf level was low. topped it up but still the same. Some ppl say that the plated have been burnt inside Link to comment Share on other sites More sharing options...
Osei Posted January 25, 2017 Share Posted January 25, 2017 Very possible the clutch plates have been burnt. Try a bottle of TransX Medic. If still no go, you'll have to get it to a shop for a formal death certificate. O. Link to comment Share on other sites More sharing options...
PurpleSNow Posted November 1, 2017 Author Share Posted November 1, 2017 tookk me long enough but i found parts from a donor trans and replaced the plates that was burnt. they were almost metal on metal. car is much better now. I must say that mt trans is a mother to take out by yourself. now after a few months there seems to be a new symptom, it locks in 3rd and then it releases then goes to 4th or thats how it feels when u drive. might this be the stopping band adj. but this started a while later. Link to comment Share on other sites More sharing options...
