fullerslgt Posted December 20, 2016 Share Posted December 20, 2016 I know every car is different and tuner quality helps a lot but I'm trying to get an idea of what hp numbers I should be expecting. Should I be looking 300, 350, or closer to 400 for ballpark numbers? Car is finished and will be getting a tune soon. Just curious. List of mods below. Thanks for the help. 2005lgtSemibuilt 2.5 sti shortblock:Manley crankshaftManley turbotuff rodsJE pistonsKing race bearingsUpgraded oil pumpMoroso oil pickup Blouch dom2.5xtrPerrin inletTomei 252 camsInjector dynamics 1000cc'sCobb fuel pumpTomei headersCobb catted hiflow downpipe3inch catbackCobb sf intakeProcess west top mountAccess port sub002 Link to comment Share on other sites More sharing options...
LatentWagen Posted December 20, 2016 Share Posted December 20, 2016 Should I be looking 300, 350, or closer to 400 for ballpark numbers? All 3 of those numbers, it depends on the gas and boost levels, and the dyno. With a 2.5XTR on a standard dyno, I'd expect 400WHP on pump at 20PSI, 350 at 15PSI. On a low reading dyno 15PSI might only make 300WHP. Why'd you go with 252s? Seems like a big turbo choice for a mid-range cam. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
fullerslgt Posted December 20, 2016 Author Share Posted December 20, 2016 Well the motor was torn apart and we didn't want to do anything too crazy but figured they'd be a little stronger than stock cams. The turbo I got a great deal on from a friend, never used. I will probably end up doing an ethanol tune along with a 93 octane tune. Link to comment Share on other sites More sharing options...
LatentWagen Posted December 20, 2016 Share Posted December 20, 2016 Was just curious about the cams... it will be interesting to see what your torque curve looks like, E should really wake that turbo up. Any other massaging on the heads? LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
CapnJack Posted December 20, 2016 Share Posted December 20, 2016 You are in the range on E85 where you may want to look at upgrading fuel pump wiring and possibly a fuel pressure regulator. You may not have issues, but I know I saw it in mine when I was approaching those numbers. I had the same injectors and when I approached near 90% IDC, I started to see some fuel pressure drop off on the factory FPR and some voltage drop on the pump. I upgraded both and no more issues. I had thought about fuel rails, but it was not needed at my level (~400 WHP on E85) How about an AOS? You are in the range when you may benefit from it and it is good insurance. If you are still on the factory boost control solenoid, a three port (Grimmspeed or others) may also benefit you. How's your clutch and transmission? At those levels, if you are stock or near stock, the clutch won't last long. Blast plates are a nice adder for the 5MT at those levels. What UP are you using? Is it EWG or internal WG? Not that it matters, just curious. Link to comment Share on other sites More sharing options...
