arg36 Posted November 13, 2016 Share Posted November 13, 2016 In my seemingly never ending quest to cure my Bug Eye Impreza 2.5RS of its misfire codes, I just pulled the fuel injectors and had them cleaned and flow tested. All came back within spec after cleaning, and were installed with new O-Rings on the injectors and in the fuel rail itself. Despite being bolted fully down, I can't quite get the fuel rail down far enough to get the clips that slide on the fuel rail and injectors to seat properly (although I do think corrosion on both parts is partly to blame) I've thoroughly test driven the car and found no leaks or loss in fuel pressure. Whats everyone think? Good enough for a beater?http://uploads.tapatalk-cdn.com/20161113/0b22d1c6b50e46184122be9b0c35238c.jpghttp://uploads.tapatalk-cdn.com/20161113/ba14b6f29a7d818fc9c561937d5d5a7e.jpg Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 14, 2016 Share Posted November 14, 2016 I would try to find a replacement hard pipe/rail for that side ASAP. Corrosion isnt good but if it wont seat properly something is askew. Link to comment Share on other sites More sharing options...
nads Posted November 14, 2016 Share Posted November 14, 2016 Did you lube the injector o-rings? Like with motor oil or Petroleum jelly? You may have gotten the wrong size seals and they are too big. I agree with Gee, get better rails too. Link to comment Share on other sites More sharing options...
