friedkin Posted October 13, 2016 Share Posted October 13, 2016 reverse light of my legacy doesnt work so I dont know where it placed on the automatic transmission? can someone describe or take a photo? I will try cleaning first. Link to comment Share on other sites More sharing options...
Brighton96 Posted October 13, 2016 Share Posted October 13, 2016 reverse light of my legacy doesnt work so I dont know where it placed on the automatic transmission? can someone describe or take a photo? I will try cleaning first. If I remember right, it's in the shifter assembly in the center console Its the little black box with the 2 wires running to it http://i1317.photobucket.com/albums/t637/96Brighton/DSCN2976_zpsahmtwsd4.jpg Link to comment Share on other sites More sharing options...
friedkin Posted October 13, 2016 Author Share Posted October 13, 2016 I didnt find any info on the net search but I found only that it can be placed on the transmission box... or it may be placed on shifter assembly as you say... and maybe I need new one but which part should I buy on the list below? any help? https://partsouq.com/en/catalog/genuine/groups?c=Subaru+Europe&ssd=%24HSUzdAJ2cQd_ZgM_IkkAAAUGA01ddlpdTkxsdFJeQ39PWx8jAkdbFA%24&vid=187 Link to comment Share on other sites More sharing options...
1692 Posted October 13, 2016 Share Posted October 13, 2016 I hate to sound like a jerk, but have you checked the bulbs themselves to make sure they aren't burned out? The turn signal bulb is also a 1156, so if you know that works, switch it out just in case and test it... I had a similar issue where neither of mine were working, and found that the wiring inside my wagon lid had been cut (most llikely by me not paying attention during another mod), so I had to put in a connection and they worked again. I think Brighton96 is correct that the little box is the correct one. As for the part on the list, I'm not 100% sure. This might be a part that you may need to find in a junkyard since they may be hard to come by. Link to comment Share on other sites More sharing options...
Brighton96 Posted October 14, 2016 Share Posted October 14, 2016 I have thought about it more and I'm pretty sure that box/switch is the parking safety switch since it's in contact with the shifter only in the park position. The one I think it may be is the white solenoid seen here But in all honesty I'm not certain, if the bulbs were fine then I'd go to a junkyard and pull all of the sensors and switches in the shifter assemble and see if that fixes it. I can't imagine it'd be more then a few dollars. http://i1317.photobucket.com/albums/t637/96Brighton/DSCN2975_zps3n3t2cvo.jpghttp://i1317.photobucket.com/albums/t637/96Brighton/DSCN2974_zps1a3av9lj.jpg Link to comment Share on other sites More sharing options...
friedkin Posted October 14, 2016 Author Share Posted October 14, 2016 thakns guys for advices... I will check them as soon as possible... Link to comment Share on other sites More sharing options...
