ihazapear Posted October 12, 2016 Share Posted October 12, 2016 Hey guys so I have some xxr 536's that are white with a chrome lip. Winter is creeping up on us here in Colorado and since this is my first winter owning a nice set of wheels that I want to take care of I would like to get some opinions on whether or not I should leave these wheels on or put the stock wheels back on. Basically everyone I've talked to about this has either said I have to swap them because the salt and sand put on the roads will ruin my wheels or that its pointless to swap them and I'm stupid if I put the stock wheels back on for winter. Any input helps thanks! Sent from my SM-G920T using Tapatalk Link to comment Share on other sites More sharing options...
ihazapear Posted October 12, 2016 Author Share Posted October 12, 2016 http://uploads.tapatalk-cdn.com/20161012/8ac44ac213dbf6e8e62deffc83b0882e.jpg here are the wheels I got if it helps. Sent from my SM-G920T using Tapatalk Link to comment Share on other sites More sharing options...
Ellesedil Posted October 12, 2016 Share Posted October 12, 2016 Are you planning on running winter tires? Stock wheels + winter tires sounds like a winning combination for me, is one I did while living in New England. Then you can keep your nice wheels with whatever summer tire you run. Link to comment Share on other sites More sharing options...
nads Posted October 12, 2016 Share Posted October 12, 2016 owning a nice set of wheels that I want to take care of I think you answered your own question. If you have he stock wheels why not use them? Link to comment Share on other sites More sharing options...
dgoodhue Posted October 12, 2016 Share Posted October 12, 2016 Any uncoated surfaces will oxidize faster with the salt mixture applied to the road. Pot holes, paving rocks from the road disintegrating (plows/pot holes), and the abrasiveness of the salt/sand mixture is much more likely to damage your wheels. If you are trying to keep them looking mint, get another set of wheels. I can tell you from my own experience on my stock wheels, you might be able get away with one winter with minimal damage, but inevitably they are going to get some noticeable damaged. Link to comment Share on other sites More sharing options...
DugsSin Posted October 12, 2016 Share Posted October 12, 2016 Put the stock wheels back on. Sweet 536's which would pack solid with ice & snow . Watch those perimeter studs they do work loose & disappear Link to comment Share on other sites More sharing options...
ehsnils Posted October 12, 2016 Share Posted October 12, 2016 Are you planning on running winter tires? Stock wheels + winter tires sounds like a winning combination for me, is one I did while living in New England. Then you can keep your nice wheels with whatever summer tire you run. Stock rims with the best set of winter tires you can find. Don't cheap out there. The only downside is that if you have good tires the risk of getting rear-ended by a moron not having winter tires increases. Link to comment Share on other sites More sharing options...
Unsp0kn Posted October 12, 2016 Share Posted October 12, 2016 Swapping to a winter wheel/tire setup is a must, especially where you live. Link to comment Share on other sites More sharing options...
