Mrstacy Posted September 25, 2016 Share Posted September 25, 2016 Is a tool needed? Don't want to crack bulb in socket Link to comment Share on other sites More sharing options...
FLlegacy Posted September 25, 2016 Share Posted September 25, 2016 http://uploads.tapatalk-cdn.com/20160925/4b14c7f9d1b94fb08d6cf0a4168f2df8.jpg This is what I used, lol. Just rock it back and forth to loosen it up. Using a steel tool will break the bulb. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Mrstacy Posted September 25, 2016 Author Share Posted September 25, 2016 Is that like mouse pad material? ? Link to comment Share on other sites More sharing options...
FLlegacy Posted September 25, 2016 Share Posted September 25, 2016 Fingers lol, they are calloused sooo... Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Mrstacy Posted September 25, 2016 Author Share Posted September 25, 2016 It will be funny once I get the bulb out. Til then... Link to comment Share on other sites More sharing options...
Mrstacy Posted September 25, 2016 Author Share Posted September 25, 2016 Hmm.it is out but not lighting up. Works when headlights are on ?? Link to comment Share on other sites More sharing options...
Mrstacy Posted September 25, 2016 Author Share Posted September 25, 2016 No must be a fuse. Won't work on any light setting Link to comment Share on other sites More sharing options...
FLlegacy Posted September 25, 2016 Share Posted September 25, 2016 Which trunk bulb? Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted September 25, 2016 Share Posted September 25, 2016 If you are replacing with an led they only work one way try turning the bulb around. Also make sure the wire leads are making good contact. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Humble Rumble Posted September 25, 2016 Share Posted September 25, 2016 Watch this video: Shows a good number of bulb repalcements in depth for our cars. And you don't need the tools they use to accomplish it. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
Mrstacy Posted September 25, 2016 Author Share Posted September 25, 2016 Which trunk bulb? Sent from my SAMSUNG-SGH-I337 using Tapatalk The interior trunk Link to comment Share on other sites More sharing options...
Mrstacy Posted September 25, 2016 Author Share Posted September 25, 2016 If you are replacing with an led they only work one way try turning the bulb around. Also make sure the wire leads are making good contact. Sent from my SAMSUNG-SGH-I337 using Tapatalk Flipped it. Still no light Link to comment Share on other sites More sharing options...
FLlegacy Posted September 25, 2016 Share Posted September 25, 2016 Check the fuse for the biu Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Mrstacy Posted September 25, 2016 Author Share Posted September 25, 2016 Hm. I noticed I had several fuses missing from the map on the inside fuse box map. when I replaced them, I now get a hum (like the old tvs test pattern sound) with anything other than auto headlights and the door open. Maybe this is a feature that I didn't know about? Link to comment Share on other sites More sharing options...
Mrstacy Posted September 25, 2016 Author Share Posted September 25, 2016 Check the fuse for the biu Sent from my SAMSUNG-SGH-I337 using Tapatalk I swapped with same result. maybe the trunk sensor is broken? or the wire cut. I can live with it. thanks for the ideas though. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted September 25, 2016 Share Posted September 25, 2016 when I replaced my trunk light, I used a LED light strip.... now there is actually usable light in there... https://smile.amazon.com/iJDMTOY-18-SMD-5050-Strip-Interior-Illumination/dp/B009K6IW00/ref=sr_1_1?s=automotive&ie=UTF8&qid=1474839050&sr=1-1&keywords=led+trunk+light Link to comment Share on other sites More sharing options...
Picky1 Posted September 25, 2016 Share Posted September 25, 2016 I did the same, added a couple small LED strips in the trunk now you can see what you are doing. Still trying to figure out the best way to get an under hood light, anyone ever try? Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted September 25, 2016 Share Posted September 25, 2016 I just use this: https://smile.amazon.com/California-Auto-Tech-35255377-Rechargeable/dp/B016KC04DO/ref=sr_1_1?s=hi&ie=UTF8&qid=1474844187&sr=1-1&keywords=cat+work+light and this: https://smile.amazon.com/Cat-Work-Lights-CT1000-Flashlight/dp/B012BR6D1E/ref=sr_1_2?s=hi&ie=UTF8&qid=1474844187&sr=1-2&keywords=cat+work+light Link to comment Share on other sites More sharing options...
brandon.mol Posted September 26, 2016 Share Posted September 26, 2016 I did the same, added a couple small LED strips in the trunk now you can see what you are doing. Still trying to figure out the best way to get an under hood light, anyone ever try? A simple hood pin switch for an alarm system along with a single fused wire to the battery positive terminal and you'd be good to go. Just ground to the hood. Link to comment Share on other sites More sharing options...
GTEASER Posted September 26, 2016 Share Posted September 26, 2016 If you added fuses where the were none, I would be concerned about the humming sound eventually burning my car down. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
islandborn Posted September 27, 2016 Share Posted September 27, 2016 Might have turned on your ability to go ludicrous speed. Link to comment Share on other sites More sharing options...
Mrstacy Posted September 27, 2016 Author Share Posted September 27, 2016 ^^^ yep. will have to undo this. if it is not broke... Link to comment Share on other sites More sharing options...
Mrstacy Posted October 9, 2016 Author Share Posted October 9, 2016 fixed. my broken light. it was simply unplugged. did led for no reason . very little usable light Link to comment Share on other sites More sharing options...
Mrstacy Posted October 9, 2016 Author Share Posted October 9, 2016 when I replaced my trunk light, I used a LED light strip.... now there is actually usable light in there... https://smile.amazon.com/iJDMTOY-18-SMD-5050-Strip-Interior-Illumination/dp/B009K6IW00/ref=sr_1_1?s=automotive&ie=UTF8&qid=1474839050&sr=1-1&keywords=led+trunk+light I ended up buying one, but some have asked for a picture. Mine is not shipped yet. thanks! Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 10, 2016 Share Posted October 10, 2016 This is the result with the included wiring kit. I could have centered it but there really is no need.... http://i298.photobucket.com/albums/mm273/anhyeuemmaimai/car%20trunk.jpg Link to comment Share on other sites More sharing options...
