WahooNo2 Posted September 26, 2016 Share Posted September 26, 2016 19.8 city and 22-29 on highway for me. 22 if going over 70 on the highway 26 if going around 65 on highway 29 or more if wife drives. stg 1 cobb ots map with kn filter, rotella t6 Link to comment Share on other sites More sharing options...
TonyF Posted September 26, 2016 Share Posted September 26, 2016 avg 22 mpg combination of city, highway and track/autocross Link to comment Share on other sites More sharing options...
obikenobi27 Posted September 26, 2016 Share Posted September 26, 2016 This last fill-up, I got a whopping 19.74 mpg after going 298.4 miles. I'm going to look at CovertRussian's threads a little more... Fuelly Report Sep 23 2016 Miles 298.4 Gallons 15.113 Cost/Gallon $2.569 Total Spent $38.82 MPG 19.7 Edit: I don't usually let the tank run so low. There was the fuel crisis in South eastern America so I was holding out on paying 50 to 60 dollars for a tank of gas. Link to comment Share on other sites More sharing options...
Phate Posted September 26, 2016 Share Posted September 26, 2016 So for the last month I've been driving back and forth from Albany to New Hampshire for the week, then back to Albany for the weekend. Heading out, I generally average somewhere in the mid-high 25's driving 74-78 the whole way, aside from hitting traffic on 495. During the week just driving around town and between work and my hotel, the average generally drops to the low 22's or high 21's. This generally includes a significant amount of driving like a dick out of boredom. Refill the tank, reset trip A, and I get similar (if a bit better) results driving home. 26-27 average going a bit slower since I'm in less of a hurry, 70-75mph. Trip B is currently somewhere in the high 18's low 19's, which I set immediately after I did my last oil change and went stage 2. This does not account for the slight speedometer error (reads 2mph low at 75)due to running oversize tires. If my accord was less janky at the moment, I'd have just driven that out here. My record with that was 37mpg on a highway trip. Link to comment Share on other sites More sharing options...
covertrussian Posted September 26, 2016 Share Posted September 26, 2016 This last fill-up, I got a whopping 19.74 mpg after going 298.4 miles. I'm going to look at CovertRussian's threads a little more... ..... Edit: I don't usually let the tank run so low. There was the fuel crisis in South eastern America so I was holding out on paying 50 to 60 dollars for a tank of gas. Was that highway or city or mixed? Also I don't let my tank run below 1/2 empty, the less liquid fuel taking up the space, the more room for liquid fuel to turn into gas. This does get recouped by the charcoal canister that then feeds into the intake, but the length of time that takes or how efficient it is, is debatable. This does not account for the slight speedometer error (reads 2mph low at 75)due to running oversize tires. 2mph off speedometer will be about .5-1mpg off, since new tires are oversized it will be calculating less then what you really are making. When I go on long trips I reset my GPS and odometer, then find the difference between the two and apply that to all of my MPG calculations, very easy in a spreadsheet. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
obikenobi27 Posted September 27, 2016 Share Posted September 27, 2016 Was that highway or city or mixed? Also I don't let my tank run below 1/2 empty, the less liquid fuel taking up the space, the more room for liquid fuel to turn into gas. This does get recouped by the charcoal canister that then feeds into the intake, but the length of time that takes or how efficient it is, is debatable. 2mph off speedometer will be about .5-1mpg off, since new tires are oversized it will be calculating less then what you really are making. When I go on long trips I reset my GPS and odometer, then find the difference between the two and apply that to all of my MPG calculations, very easy in a spreadsheet. Mostly city driving. 2 hours on the highway going to Cary for some Subaru OEM stuff. Link to comment Share on other sites More sharing options...
covertrussian Posted September 27, 2016 Share Posted September 27, 2016 That's about 130m highway and 168m city then, while that's not quite 50/50, I would expect you to be closer to 22-24mpg assuming your city is around 19ish. If you really wanna start keeping track of it, try to avoid doing city miles on highway trips. Fillup, do two hours of driving (at least 120miles or 4 gallons), fillup, do city driving. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
sunny5280 Posted September 27, 2016 Share Posted September 27, 2016 The trip computer says I obtain 17-18 around town and 26-27 on the highway though I'm not sure how accurate the trip computer is. I gave up on tracking my fuel economy as I concluded it's going to be what it's going to be. While driving habits can impact fuel consumption I've reached the conclusion I'm just going to drive the car without worrying about it. I bought my Outback XT for the fun factor and I'm not going to drive it like a grandma going to church on Sundays. Link to comment Share on other sites More sharing options...
