lgt777 Posted September 6, 2016 Share Posted September 6, 2016 Hey guys i'm new to this form and i was wondering if my 2005 legacy gt will bolt on a vf46 or vf52 turbo with no other modifications. My vf40 just blew up and i am wondering if i should get a new vf40 or upgrade to the vf46 or vf52. Link to comment Share on other sites More sharing options...
tanner12 Posted September 7, 2016 Share Posted September 7, 2016 I'm not sure about the 46, but for the 52 you would need upgrades to the fuel system as well I believe. I'm thinking its a upgraded fuel pump and injectors iirc Link to comment Share on other sites More sharing options...
Rhitter Posted September 7, 2016 Share Posted September 7, 2016 All those will bolt on without any modifications. However, and unless you get tuned for those Turbos there is no reason to move to them. Unless you get a new tune (for the vf52) you won't get more out of it. The VF46 isn't really an upgrade to a 40. With a blown turbo there are other things you need to inspect otherwise your car will keep eating them. Look at the blown turbo wiki. My OBXT build Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 7, 2016 Share Posted September 7, 2016 VF46 (this is essentially the same turbo as the VF40) yes VF52 yes but you'll need a tune to run it (this is an actual power upgrade) Shoot us a message if you are looking to upgrade. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
lgt777 Posted September 7, 2016 Author Share Posted September 7, 2016 All those will bolt on without any modifications. However, and unless you get tuned for those Turbos there is no reason to move to them. Unless you get a new tune (for the vf52) you won't get more out of it. The VF46 isn't really an upgrade to a 40. With a blown turbo there are other things you need to inspect otherwise your car will keep eating them. Look at the blown turbo wiki. Thanks for the responses guys! Ya i was planning on doing a downpipe and upipe as well as a tune to get it all done together. And i believe the turbo went bad because of the previous owner starving the car from oil once and he said its screwed the turbo up since. I also had it checked out by RA Worx just to make sure there was no more damage and to confirm it was the turbo that was blown. My last question is the td05-18g a better option than the vf52? Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 8, 2016 Share Posted September 8, 2016 Thanks for the responses guys! Ya i was planning on doing a downpipe and upipe as well as a tune to get it all done together. And i believe the turbo went bad because of the previous owner starving the car from oil once and he said its screwed the turbo up since. I also had it checked out by RA Worx just to make sure there was no more damage and to confirm it was the turbo that was blown. My last question is the td05-18g a better option than the vf52? VF52 will be a better daily turbo, while still giving you the extra power over stock. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
rang0 Posted September 8, 2016 Share Posted September 8, 2016 This was the exact same scenario I was in around this time last year. My VF40 went and I decided to replace that with a VF52. I also did a grimmspeed catted downpipe, catless uppipe, intake, tgv deletes, and catback exhaust. I then went straight to Tuning Alliance for a Dyno-tune session and made 263awhp/270awtq on the final tune. Really happy with how it ran. The only thing to note was my stock clutch started slipping on the dyno and then on the road after... so I had to replace my clutch. All in all, I recommend doing the vf52 and a few supporting mods. Really brightens up the car, especially with the guys at TA. Good luck. Link to comment Share on other sites More sharing options...
lgt777 Posted September 8, 2016 Author Share Posted September 8, 2016 This was the exact same scenario I was in around this time last year. My VF40 went and I decided to replace that with a VF52. I also did a grimmspeed catted downpipe, catless uppipe, intake, tgv deletes, and catback exhaust. I then went straight to Tuning Alliance for a Dyno-tune session and made 263awhp/270awtq on the final tune. Really happy with how it ran. The only thing to note was my stock clutch started slipping on the dyno and then on the road after... so I had to replace my clutch. All in all, I recommend doing the vf52 and a few supporting mods. Really brightens up the car, especially with the guys at TA. Good luck. Thanks man ill be upgrading to the vf52 then. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 8, 2016 Share Posted September 8, 2016 Thanks man ill be upgrading to the vf52 then. Make sure to use only an IHI one, and not any "custom upgrade" one. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2016 Share Posted September 8, 2016 Can Brian get you a price on a vf52 ? I'm sure you can PM him. Can't say enough, buy these type parts from a Vendor on the forum, you can trust them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 9, 2016 Share Posted September 9, 2016 Can Brian get you a price on a vf52 ? I'm sure you can PM him. Can't say enough, buy these type parts from a Vendor on the forum, you can trust them. They are like 1200 new, better to find a blown one 200-300 and rebuild it for 250 bucks. What I did with mine. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
lgt777 Posted September 9, 2016 Author Share Posted September 9, 2016 They are like 1200 new, better to find a blown one 200-300 and rebuild it for 250 bucks. What I did with mine. -Brian Ya that's what i was going to do, seems better than paying 1200 lol. Thanks Guys! Link to comment Share on other sites More sharing options...
LegUp Posted September 12, 2016 Share Posted September 12, 2016 Are there any ball bearing turbo options for our cars? I haven't found any yet. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 13, 2016 Share Posted September 13, 2016 There BB turbo's that will work, you just have to do a custom set up. Just depends on how much you want to spend. Brian may know more...? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
NSFW Posted September 26, 2016 Share Posted September 26, 2016 ATP offers Garrett turbos that are BB, but STI fitment, so you need a new intercooler at Ieast. I think AVO still does BB bolt-in turbos. Both are a little spendy compared to a used stock turbo of course. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 26, 2016 Share Posted September 26, 2016 Are there any ball bearing turbo options for our cars? I haven't found any yet. There BB turbo's that will work, you just have to do a custom set up. Just depends on how much you want to spend. Brian may know more...? Don't think so for direct fitment. If you are going down that route I highly suggest you look into Borg Warner EFR turbos over BB. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
NSFW Posted September 27, 2016 Share Posted September 27, 2016 There's also KillerB's stock-location Garrett GTX setups. Spendy but they make good stuff, I have their exhaust manifold. If I were starting over today I'd probably go that route rather than the ATP turbo that I bought a few years ago. Link to comment Share on other sites More sharing options...
LegUp Posted September 27, 2016 Share Posted September 27, 2016 I have a GrimmSpeed TMIC, they sell a turbo output hose that lets you run a STI turbo, so I might look into those. My question is whether the oil and coolant lines would fit, or would I have to replace/ modify them to line up with the STI fitment turbo? Link to comment Share on other sites More sharing options...
