FreePalestine Posted August 24, 2016 Share Posted August 24, 2016 Hey guys, So i have a 2009 Legacy, and i'm planning to buy another one for spare parts, and ran into a 2006 Legacy, The question here is are they the same? let's say if i want to swap anything. Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2016 Share Posted August 24, 2016 There are some differences but, I don't think there are enough that are the same to make it worth it. Are we talking a 2.5i ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FreePalestine Posted August 24, 2016 Author Share Posted August 24, 2016 There are some differences but, I don't think there are enough that are the same to make it worth it. Are we talking a 2.5i ? No, i have a 2.0 Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2016 Share Posted August 24, 2016 Well I guess your not in the USA...? I'm still going to think there are to many differences to make it worth your while. Here the 07-09's have different front and rear body parts the gauges are different and the hvac and radio. The engine have different fuel rails and an air pump. Not that some of those parts can't be swapped over but some would take some electrical work. I guess it depends how cheap the 06 is and what your comfort level is with DIY. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rougeben83 Posted August 25, 2016 Share Posted August 25, 2016 what do you plan to keep? If you have the same engine/trans combo, most if not all the hardware should be interchangeable. Suspension too. Interior should not have a lot of differences. The exterior varied in the different years/markets so that may be the biggest difference. Link to comment Share on other sites More sharing options...
