covertrussian Posted August 23, 2016 Share Posted August 23, 2016 Any of you getting thumps during hard shifts? Common cause for other cars is bad motor mounts but from what I could tell mine look fine, though it might be the new style front mount (I miss the pitchstop kind of mount). It's funny that my 05 GT has a much quieter reving motor and doesn't mind hard shifts at all, but the 12 outback feels more like a truck 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2016 Share Posted August 24, 2016 Is there a STi tranny mount you can install. When I put that on my 05 wagon back shortly after I bought it, it made a big difference by tightening up the drivetrain. The STi rear tranny mount is a solid chunk of rubber. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
covertrussian Posted August 25, 2016 Author Share Posted August 25, 2016 I'll have to take a look, there might be something but only if WRX's switched away from pitch stops too. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
ToRealEyes Posted August 30, 2016 Share Posted August 30, 2016 The thump you describe sounds familiar. Has existed since new. The ouback has taught me to shift quick, not hard. Easily one of the less forgiving modern transmissions I've driven, wife is terrified of driving it in stop/go or on slopes. Let us know if you find something that helps. Link to comment Share on other sites More sharing options...
covertrussian Posted August 31, 2016 Author Share Posted August 31, 2016 I guess I'm kind of happy to hear that this is normal, but annoyed that there might not be an easy fix (like replacing a motor mount). I'm gonna also try to replace the shifter bushing and do the clutch damper bypass, either of those two might be preventing a proper shift. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
