MaStaMooN Posted August 14, 2016 Share Posted August 14, 2016 Anybody have an idea why this may be. Ive included the LV log along with a quick log from rom raider... The LV log doesnt seem very helpful. [19:54:01.2542141] Learning View version 0.6a [19:54:05.9810224] PassThruOpen returned 0 and DeviceID 1 [19:54:05.9810224] PassThruReadVersion returned 0 [19:54:05.9810224] Device firmware version: 1.16.4769 [19:54:05.9810224] DLL version: 1.02.4798 Jun 13 2016 17:16:24 [19:54:05.9810224] API version: 04.04 [19:54:05.9966224] PassThruConnect returned 0 and ChannelID 3 [19:54:05.9966224] PassThruStartMsgFilter returned 0 [19:54:06.0122224] ECU Init [19:54:06.0590225] PassThruWriteMsgs returned 0 [19:54:06.0590225] WRITE 6 bytes: 80 10 F0 01 BF 40 [19:54:08.0714261] PassThruReadMsgs returned 16 [19:54:08.0714261] PassThruGetLastError returned 16, Message: no data was read [19:54:08.0714261] READ ERROR: PassThru Error [19:54:10.6766306] PassThruDisconnect returned 0 [19:54:10.6922307] PassThruClose returned 0 Laptop is Win7 x64, Tactrix 2.0, 32-bit Java... It seems to grab my ECU ID and ROM ID.. but then errors. See picture.romraiderlog_20160813_195313.csv Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
fahr_side Posted August 14, 2016 Share Posted August 14, 2016 Does ECUflash work? You know only one application can use the OP2 port at once eh? If RR logger is connected LV can't, and vice versa. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Andy_Mac Posted August 14, 2016 Share Posted August 14, 2016 Same problem i've been having recently. Seems quite a few others over on the romraider forum have been too. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
MaStaMooN Posted August 14, 2016 Author Share Posted August 14, 2016 Does ECUflash work? You know only one application can use the OP2 port at once eh? If RR logger is connected LV can't, and vice versa. Not sure, I didnt want to have it ready my ecu since it resets it and I wanted to get a live view of the current status of the car. And I wasn't using both at the same time. Sent from my Nexus 6 using Tapatalk Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
MaStaMooN Posted August 15, 2016 Author Share Posted August 15, 2016 Looks like im using an old version of Learning view.. ill try the newer version , but it looks like others are having issues with the newer version also... Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
MaStaMooN Posted August 16, 2016 Author Share Posted August 16, 2016 Tried the latest version of Learning View... no go... uninstalled java 8, installed java 7... no go.. but the log looks like it got a little further or something. Or maybe the logging is more verbose than the old version.. idk. [20:01:57.1109128] Learning View version 1.0 RC3 [20:02:00.9329195] PassThruOpen returned 0 and DeviceID 1 [20:02:00.9329195] PassThruReadVersion returned 0 [20:02:00.9329195] Device firmware version: 1.16.4769 [20:02:00.9329195] DLL version: 1.02.4798 Jun 13 2016 17:16:24 [20:02:00.9329195] API version: 04.04 [20:02:00.9329195] PassThruConnect returned 0 and ChannelID 3 [20:02:00.9329195] PassThruStartMsgFilter returned 0 [20:02:00.9641195] ECU Init [20:02:01.0109196] PassThruWriteMsgs returned 0 [20:02:01.0109196] WRITE 6 bytes: 80 10 F0 01 BF 40 [20:02:01.0733197] PassThruReadMsgs returned 0 [20:02:01.0733197] READ 0 bytes [20:02:01.1669199] PassThruReadMsgs returned 0 [20:02:01.1669199] READ 62 bytes: 80 F0 10 39 FF A2 10 11 2F 12 78 52 06 73 FA CB A6 2B 81 FE A8 00 81 00 60 CE 54 F9 B1 E4 00 0C 20 00 00 00 00 00 DC 00 00 5D 1F 30 C0 F2 26 00 00 43 FB 00 E1 00 00 00 00 00 00 C1 F0 A9 [20:02:01.8533211] ECU supported (ECUID:2F12785206 CALID:A2WC510N DESC:05 USDM Legacy GT MT): [20:02:01.8689211] Auxillary Parameters [20:02:01.9781213] PassThruWriteMsgs returned 0 [20:02:01.9781213] WRITE 16 bytes: 80 10 F0 0B A8 00 00 00 23 00 00 12 00 00 08 70 [20:02:04.0217249] PassThruReadMsgs returned 16 [20:02:04.0217249] PassThruGetLastError returned 16, Message: no data was read [20:02:07.1261304] An error has occured: PassThru Error [20:02:07.1261304] PassThruDisconnect returned 0 [20:02:07.1417304] PassThruClose returned 0 Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
fahr_side Posted August 16, 2016 Share Posted August 16, 2016 You know LV needs .net 2.0 not Java eh? Also note that the later versions of RR logger have all the LV functions built in. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
MaStaMooN Posted August 16, 2016 Author Share Posted August 16, 2016 You know LV needs .net 2.0 not Java eh? Also note that the later versions of RR logger have all the LV functions built in. Hmm. Where abouts in RR Logger is the LV snapshot? I didnt see it. Id assume if Learning View loads/runs.. you have the correct .net prereqs.. but Ill have to see what exactly windows update has installed in that regard. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
fahr_side Posted August 17, 2016 Share Posted August 17, 2016 Open logger. On the menu bar tab 'tools', options there to reset ECU, read LV values, check IAM and trouble codes. You'll need the extra logger definition files to make this work. Check here: http://www.romraider.com/forum/viewtopic.php?f=14&t=9745 Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
MasAyinde Posted August 19, 2016 Share Posted August 19, 2016 Yeah the readout from the RR LV table is pretty much identical to Learning View. So much so that I uninstalled LV. Link to comment Share on other sites More sharing options...
MaStaMooN Posted August 19, 2016 Author Share Posted August 19, 2016 I ended up buying the BtSsm app and am using it with the tactrix for LV and logging. Easier than dealing with a laptop. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
