ben64 Posted August 13, 2016 Share Posted August 13, 2016 Hi, I m wondering if when I set the heater to HIGH if there is a variation in cooling liquid circulation ( coolant is not always circulating into the radiator ) : is there another valve like the thermostat as I hear sometime a bubble noise when heater is ON and I've made the purge like the service manual said ... I suspect head gasket going down but I want to be sure is I may have an air leak with the heater ??? Thanks by advance Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2016 Share Posted August 13, 2016 The heater core and coolant system are the same loop, sorry I'cant recall if there is a diverter valve, I don't think so. You can check opposedforces for the heater system. See the post I just put in your other thread. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RustyRuu Posted August 16, 2016 Share Posted August 16, 2016 its in the loop, but not a valve, the throttle. and if you have a 3.0r in the U.S its a automatic so there are lines for that i dont know about any valve. those are just thoughts for your air leak. Link to comment Share on other sites More sharing options...
