fantasyxiv Posted August 8, 2016 Share Posted August 8, 2016 Hi there, After ordering my set of F + R sway bars I have found out that the whiteline 24mm Front sway bar is currently out of stock at white line and is currently in a production run with no Eta available at this stage which is a bummer because all the performance shops here that "claim" to have it in stock is code for we order it from whiteline then send it to you. I have managed to find in stock the Cusco 25mm front sway bar part number# 687 311 A25 which is supposedly the correct bar for the front of my car. I just wanted to confirm that this is the correct front sway bar and also if this bar will be compatible with the Front Whiteline heavy duty end links that I have also ordered. Also dose anyone have any experience with this bar also? Any information will be much appreciated. Link to comment Share on other sites More sharing options...
Perscitus Posted August 8, 2016 Share Posted August 8, 2016 Hey fantasyxiv, it most likely will fit, but given the funky geometry of the front bar on the LGT and at 25mm I'd err on the side of caution and instead pickup a SuperPro 24mm front sway (its identical to the Whiteline). I believe you should have no issues picking one up down in Ozz. http://www.superpro.com.au/find/superpro-suspension-parts-and-poly-bushings-for-subaru-liberty-bm-sedan-br-wagon-9-2009-on-/cid-999501268 While at it, check out their endlinks (they have a great set for our rear, same part as on the BRZ, 2015 WRX, etc.). The Whiteline HD ones tend to clunk and squeak with time. http://www.superpro.com.au/find/superpro-bushing-kit-for-a-superpro-suspension-parts-and-poly-bushings-for-subaru-brz-zc6-2012-on-/productnr-SPF3915K/cid-999501126/vid- For the front endlinks I'd recommend Rallitek over any other (I have tried perhaps 4 brands by now on three Subarus and they are a great compliment for the Superpro rears): http://www.rallitek.com/endlinks/5631-rallitek-hd-front-endlinks-wrx-2002-2014-sti-2004-2014-forester-2003-2013-legacy-outback-2005-2009-more-1.html Or perhaps these SuperPros would fit too: http://www.superpro.com.au/find/superpro-sway-bar-link-kit-for-a-superpro-suspension-parts-and-poly-bushings-for-subaru-liberty-bm-sedan-br-wagon-9-2009-on-/productnr-TRC1225/cid-999501268/vid- Link to comment Share on other sites More sharing options...
fantasyxiv Posted August 9, 2016 Author Share Posted August 9, 2016 Hey fantasyxiv, it most likely will fit, but given the funky geometry of the front bar on the LGT and at 25mm I'd err on the side of caution and instead pickup a SuperPro 24mm front sway (its identical to the Whiteline). I believe you should have no issues picking one up down in Ozz. http://www.superpro.com.au/find/superpro-suspension-parts-and-poly-bushings-for-subaru-liberty-bm-sedan-br-wagon-9-2009-on-/cid-999501268 While at it, check out their endlinks (they have a great set for our rear, same part as on the BRZ, 2015 WRX, etc.). The Whiteline HD ones tend to clunk and squeak with time. http://www.superpro.com.au/find/superpro-bushing-kit-for-a-superpro-suspension-parts-and-poly-bushings-for-subaru-brz-zc6-2012-on-/productnr-SPF3915K/cid-999501126/vid- For the front endlinks I'd recommend Rallitek over any other (I have tried perhaps 4 brands by now on three Subarus and they are a great compliment for the Superpro rears): http://www.rallitek.com/endlinks/5631-rallitek-hd-front-endlinks-wrx-2002-2014-sti-2004-2014-forester-2003-2013-legacy-outback-2005-2009-more-1.html Or perhaps these SuperPros would fit too: http://www.superpro.com.au/find/superpro-sway-bar-link-kit-for-a-superpro-suspension-parts-and-poly-bushings-for-subaru-liberty-bm-sedan-br-wagon-9-2009-on-/productnr-TRC1225/cid-999501268/vid- Thanks for the links, I've looked up the super pro catalog listing and they only do the rear sway bar, they don't make a front one. Only brands that i'm aware atm that make front sways are Whiteline and Cusco. According to Andy's motor sport that bar should fit my car as it's a BM9 model. Link to comment Share on other sites More sharing options...
Humble Rumble Posted August 9, 2016 Share Posted August 9, 2016 Since you have a 2010 and are looking to do the front sway bar anyways, which requires lifting the engine in the GT (learned that thanks to GTEASER), you do have the option to go with the 26 mm OEM front sway from the 2013-2014 models (2010-2012 have 24 mm FSB if I remember right). Part # 20401AJ08A and 20414AJ10A for the bushings. You can snag one up for only about $90 typically, and could still pair it with after market bushings or end links if you want. http://parts.subaru.com/p/Subaru__/STABILIZER-FRONT/49230248/20401AJ08A.html 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
