M4rked1 Posted July 9, 2016 Author Share Posted July 9, 2016 Most of the parts came today! Reassembly is going to take considerably longer than the tear down since I go back to work on Monday. Stay tuned I will get her back together! http://i.imgur.com/opqLDdk.jpg Link to comment Share on other sites More sharing options...
M4rked1 Posted July 15, 2016 Author Share Posted July 15, 2016 Decided the Vf40 had just a bit too much shaft play to put back on. 20k mi Vf46 is en route. http://i.imgur.com/MgQQyzZ.jpg Meanwhile the heads are back on, along with cams, valve covers and water pump. I am going to try to finish the timing belt and covers tonight. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 15, 2016 Share Posted July 15, 2016 That's good progress. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted July 16, 2016 Author Share Posted July 16, 2016 Is there a specific order that works best for reinstalling the wiring harness/intake/manifold/hoses? I kind of just unhooked everything and it all came off in a big pile, and I would like to be more systematic putting it back together. My plan at the moment is to install all the hoses I can, then the intake manifold, then the wiring harness. Also, that timing belt was a pain with the drivers side cam sprockets being loaded. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 17, 2016 Share Posted July 17, 2016 Did you take the intake system off in one piece like this ? http://i185.photobucket.com/albums/x40/92Si/DSCN4741.jpg All that is needed it new TGV gaskets. Make sure you tighten all the gas line clamps. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted July 17, 2016 Author Share Posted July 17, 2016 Thanks, I got it together after a little trial and error . Now for the million dollar question, what is this and why can't I find where it goes: http://i.imgur.com/H3rcRgo.jpg Link to comment Share on other sites More sharing options...
seanyb505 Posted July 17, 2016 Share Posted July 17, 2016 Pcv valve. Or at least part it. Should connect to a rear port on the turbo inlet. In this pic, follow the highlighted hose. There is a silver clamp near the top that is hidden by the other hoses. Your extra part should connect near the end of the highlighted hose there, and the inlet. If you bought a new pcv valve, it would have come with a new piece on that end I think. Link to comment Share on other sites More sharing options...
M4rked1 Posted July 17, 2016 Author Share Posted July 17, 2016 The car has a Perrin inlet tube, does this eliminate this piece? I'm pretty sure it wasn't hooked up when I tore the car down. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 17, 2016 Share Posted July 17, 2016 http://i185.photobucket.com/albums/x40/92Si/DSCN4750.jpg Is that it right behind that big harness in the right going into the top of the inlet tube ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted July 17, 2016 Author Share Posted July 17, 2016 Is that it right behind that big harness in the right going into the top of the inlet tube ? Yeah, I think so, thanks for the picture, I'll have to see if I can hook mine up there. Link to comment Share on other sites More sharing options...
rhino6303 Posted July 17, 2016 Share Posted July 17, 2016 The car has a Perrin inlet tube, does this eliminate this piece? I'm pretty sure it wasn't hooked up when I tore the car down. Yes it does. You just need to pull the metal tab out of the electrical connector and put it in the wire harness to eliminate an error code. Be sure to tape the wire harness connector so the metal tab doesn't fall out. Link to comment Share on other sites More sharing options...
M4rked1 Posted July 19, 2016 Author Share Posted July 19, 2016 Engine is totally assembled and new vf46 is installed, going to drop it in tonight. Plan is to start by Thursday night. http://i.imgur.com/PAfpmJZ.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted July 19, 2016 Share Posted July 19, 2016 Yes it does. You just need to pull the metal tab out of the electrical connector and put it in the wire harness to eliminate an error code. Be sure to tape the wire harness connector so the metal tab doesn't fall out. Just asking, instead of pulling the tab out, couldn't you just make a jumper cable ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rhino6303 Posted July 19, 2016 Share Posted July 19, 2016 Just asking, instead of pulling the tab out, couldn't you just make a jumper cable ? You could do that but the tab isn't attached though and pulls out easily. It can be put back without issues. Link to comment Share on other sites More sharing options...
M4rked1 Posted July 23, 2016 Author Share Posted July 23, 2016 Just about done. Need to crank with the fuel pump off to prime. I'm going to check the top banjo of the turbo to ensure oil flow. Then it's just install the intercooler and start her up! http://i.imgur.com/TW4CPYx.jpg Link to comment Share on other sites More sharing options...
M4rked1 Posted July 23, 2016 Author Share Posted July 23, 2016 It lives! Good idle, pulls hard, no weird noises, no leaks. http://i.imgur.com/cXnwgRt.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted July 23, 2016 Share Posted July 23, 2016 That's great to hear. I like these threads that are short and get things done is a real time frame. Good Job. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted July 24, 2016 Author Share Posted July 24, 2016 That's great to hear. I like these threads that are short and get things done is a real time frame. Good Job. Thanks!! I have my wife to thank for the quick timeline, lol. we have my sons first b-day coming up, and she wants to use the garage as part of the party space. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 24, 2016 Share Posted July 24, 2016 It's amazing what you can do...when you have someone...after you to get it done... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted July 26, 2016 Author Share Posted July 26, 2016 I know it's off topic for powertrains, but I didn't want to start a whole new thread... But the mothers headlight restoration kit works pretty awesome! Before: http://i.imgur.com/OEGazk0.jpg After: http://i.imgur.com/gsKV3Xt.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted July 26, 2016 Share Posted July 26, 2016 Yea, I think I use the same kit. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted August 21, 2016 Author Share Posted August 21, 2016 PSA, don't do this it sounds terrible, puts exhaust into the cabin and likely loses hp... Found the stock mufflers looked like this when I dropped them to swap in a different catback. http://i.imgur.com/QtTmT2q.jpg Link to comment Share on other sites More sharing options...
GrasshopperLGT Posted August 23, 2016 Share Posted August 23, 2016 PSA, don't do this it sounds terrible, puts exhaust into the cabin and likely loses hp... Found the stock mufflers looked like this when I dropped them to swap in a different catback. http://i.imgur.com/QtTmT2q.jpg Isn't the hogzaust easier than hacking up a muffler?? That is funny looking tho Link to comment Share on other sites More sharing options...
