friedkin Posted June 26, 2016 Share Posted June 26, 2016 what is the 1996 legacy automatic transmission oil type? is dexron III ? Link to comment Share on other sites More sharing options...
Brighton96 Posted June 26, 2016 Share Posted June 26, 2016 The manual calls for 8.3 Qts/7.9 Liters of Dex II or Dex II Link to comment Share on other sites More sharing options...
wtdash Posted June 26, 2016 Share Posted June 26, 2016 yes, you can use anything that is Dexron III compatible. Be AWARE that only 1/2 of the fluid is in the pan. The rest is in the Torque Converter/TC. Link to comment Share on other sites More sharing options...
friedkin Posted June 27, 2016 Author Share Posted June 27, 2016 are pan and tc seperate? Link to comment Share on other sites More sharing options...
doublechaz Posted June 27, 2016 Share Posted June 27, 2016 They are not separate as far as filling and level and such, but if you take the pan off and "drain" it, the TC will not drain on its own so you will have only to replace around half the total capacity to get back to full. Like all Auto Trans, don't over fill it. It will froth up, put air all through the internals, fail to clamp fully at the clutch packs slip and burn up. If you are trying to flush the entire system to get rid of old yucky fluid, you will have to take steps to drain the TC as well. There is probably something about how to do it around here, or in the Service Manual. I don't know off the top. Mine is 5MT. Link to comment Share on other sites More sharing options...
