Nightmaresmk Posted June 17, 2016 Share Posted June 17, 2016 Well my faithful 2.5 has been pushed to far. At full Boost it's pushing coolant out of the overflow. Under 20psi zero issues. The original plan was just ARP head studs and basic head gasket job sending the heads out to be cleaned and decked. Install my new header and get it retuned by mike of tuning Alliance. Well talking to Mike changed my plans now the block is getting replaced with a machined Ej255/Ej257 with king bearings and Mahle 4032 Pistons. This is a Daily driver build as this car sees 23k miles per year. Max 400whp on E85 if Cobb releases flex fuel. Currently purchased or purchasing parts. New top feed TGV deletes IAG- purchased TigWerks Fab Equal length header, Being Fabricated now Tomei 1mm Headgaskets - purchased Arp headstuds -own already 11mm Oem oil pump - Ordered with the shortblock Misc gaskets and Company 23 tools - waiting to be used. http://imageshack.com/a/img924/6773/EQMvW4.jpg I will update as I continue receiving parts and pieces. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 17, 2016 Author Share Posted June 17, 2016 http://imageshack.com/a/img923/7453/yt1zfX.jpg Current Mods installed and owned Perrin 25mm FSB, AVO 0 Caster cab, Whitline front cab Cusco 21mm RSB, AVO rear sway bar bracket reinforcements 04 KYB struts 05 Legacy GT brakes F+R DBA 4k Front rotor and Cyro's in the rear with Portfield r4s pads Infamous performance oil line V2 Moroso Oil pan and pickup Forge Bypass Valve Modified Avo Front Mount intercooler Cobb STS with perrin lockout and shifter bushings DW65 Grimmspeed Crankpully, Ceramic UpPipe, Turbo heat-shield, radiator shroud, boost controller, and gaskets. Maddad ceramic coated catted downpipe Agency power equal length header PTP lavablanket Tomioka Racing Billet 18g 2007 Spec B 6 speed with R180 and SS clutch line Raxles HD front axles Rear diff poly bushings Perrin trans mount Super pro pitch mount Group n engine mounts 2012 STI clutch with act monoloc Grimmspeed MBC brace SS brake lines ID1000's Aeromotive FPR IAG Fuel rails and dampeners 8.5mm phenolic spacers. Topfeed TGV deltes IAG street AOS Perrin coolant overflow Venair bypass tube AVO turbo inlet KSTech 73mm intake Mishimoto radiator hoses and turbo expansion tank Center console gauge with Innovate boost gauge and AEM Wideband Cobb V3 2013 Sti Front Seats Yellow top Ray Tuned 335/377 Summer tires 255/50R17 on 17x8 et 35 Rota Torques Winter tires 225/55R17 Continental Extreme winter contacts Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 17, 2016 Author Share Posted June 17, 2016 Some parts arrived. http://imageshack.com/a/img921/7428/46kUTC.jpg http://imageshack.com/a/img921/1207/ZVqBSC.jpg http://imageshack.com/a/img921/9192/WbSl0w.jpg And finally mike dropped off these to the machine shop. http://imageshack.com/a/img924/6475/OiUFjz.jpg Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 24, 2016 Author Share Posted August 24, 2016 Got the motor pulled. http://imageshack.com/a/img923/1420/vqVDlP.jpg New shortblock from Tuning alliance. http://imageshack.com/a/img923/8186/kFCtxs.jpg Heads redone from napa's machine shop in one day. http://imageshack.com/a/img923/1158/srRB4R.jpg Fuel system swapped to the new tgv's. http://imageshack.com/a/img923/3558/zgEwLf.jpg The old pistons show my issue bad. http://imageshack.com/a/img922/3329/yx011Y.jpg Link to comment Share on other sites More sharing options...
rebourne Posted September 23, 2016 Share Posted September 23, 2016 sub'd for a good rebuild thread. pic thread build thread Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 26, 2016 Author Share Posted September 26, 2016 Currently already together. received the tigwerks header. broke the v-band and haven't driven it. Buying a second car and regulating this one to spare/ play car. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 26, 2016 Author Share Posted September 26, 2016 Tigwerks header. http://imageshack.com/a/img922/3301/NY6zMb.jpg Timing. perfect http://imageshack.com/a/img921/5528/yFENqE.jpg http://imageshack.com/a/img921/1147/0hBTAi.jpg http://imageshack.com/a/img922/7105/iU5rt7.jpg All Buttoned up http://imageshack.com/a/img923/4265/4c72xj.jpg Installed waiting on finishing. http://imageshack.com/a/img922/3258/q1sImC.jpg Link to comment Share on other sites More sharing options...
LatentWagen Posted September 26, 2016 Share Posted September 26, 2016 This is quite the rebirth. Interested to see how that billet 18g does! LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 27, 2016 Author Share Posted September 27, 2016 Considering the lack of change in power parts my money is still what i had around 335/377 Link to comment Share on other sites More sharing options...
rebourne Posted September 27, 2016 Share Posted September 27, 2016 Upgrades are TGV deletes and a better header vs the Agency Power. are you dropping compression with the 1mm head gasket? Any other power part upgrades? pic thread build thread Link to comment Share on other sites More sharing options...
Flinkly Posted September 27, 2016 Share Posted September 27, 2016 Already had deletes. i imagine deleted oem, and new ones look like IAG cnc versions. New header and a fresh block suited for some power. * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
rebourne Posted September 27, 2016 Share Posted September 27, 2016 in theory the block and parts can make more power, but his previous tune was probably close to what the turbo can make on pump. Factor in dyno differences and I wouldn't bet against +/- 10% of those numbers. Too bad he is changing out the header at the same time. Would be cool to see a back to back of the clone vs the custom. pic thread build thread Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 27, 2016 Author Share Posted September 27, 2016 Well i ended up running OEM head gaskets per Mike's request. Yeah i went from deleted and ported oems to these IAG units. The header may improve lag that's all. maybe in a year or so i will look into a green or E85 flex when it comes out. Link to comment Share on other sites More sharing options...
Rester5350 Posted September 28, 2016 Share Posted September 28, 2016 Looks like a solid build. What did those headers set you back? Link to comment Share on other sites More sharing options...
LatentWagen Posted September 28, 2016 Share Posted September 28, 2016 Considering the lack of change in power parts my money is still what i had around 335/377 You can throw a lot more boost a built motor Some octane would help that turbo shine, whether race gas or E. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 29, 2016 Share Posted September 29, 2016 for some reason, your obxt seems lifted. Is it? Link to comment Share on other sites More sharing options...
Rhitter Posted September 29, 2016 Share Posted September 29, 2016 He is running 255/55/17s I think. So extra tire gets him up there. My OBXT build Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 29, 2016 Author Share Posted September 29, 2016 Yeah stock ride height. has the largest sways available. But it's the 255's that make it look big Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 29, 2016 Share Posted September 29, 2016 I see. No rubbing? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 29, 2016 Author Share Posted September 29, 2016 Nope. been running them for 3 years now maybe 50k miles. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted October 20, 2016 Author Share Posted October 20, 2016 Well some bad news. i still have a random noise from the motor that no one can diagnose. I had it running on the Tigwerks header last night for 8 minutes. took it up and down the road under 30mph under 3k rpms. pulled it into my car port walked away came back to smoke billowing out. My radiator blew. So at this point it is coming off the road. Link to comment Share on other sites More sharing options...
Rhitter Posted October 20, 2016 Share Posted October 20, 2016 Wow that sucks. Did you catch it in time? My OBXT build Link to comment Share on other sites More sharing options...
Nightmaresmk Posted October 21, 2016 Author Share Posted October 21, 2016 It didn't over heat. But the noise is leaving a bad taste in my mouth so the motor is coming back out and I'm dissecting to find that noise. I already blew my spare money I had on a new clutch a full gasket set and a bunch of misc pieces so my pockets are empty and I need parts. So the car is done for a while. Link to comment Share on other sites More sharing options...
