Sparegun007 Posted February 23, 2017 Share Posted February 23, 2017 Love ur setup ! And thanks for the picture Link to comment Share on other sites More sharing options...
Darth SpecB Posted February 23, 2017 Share Posted February 23, 2017 I ended up buying evo ones, they took some trimming but said and done fit great. Sent from my SAMSUNG-SM-G935A using Tapatalk Nice look! What size is your wheel fitment? Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
MPacMan15 Posted February 23, 2017 Author Share Posted February 23, 2017 Nice look! What size is your wheel fitment? Sent from my SAMSUNG-SM-G900A using Tapatalk Thanks guys! Wheel size is 18x9.5 et33 with a 225/40 tire Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 24, 2017 Share Posted February 24, 2017 Thanks guys! Wheel size is 18x9.5 et33 with a 225/40 tire Avid.1 AV20's? 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
madrig Posted February 24, 2017 Share Posted February 24, 2017 Avid1 AV20 18x9.5 +38 ? i dont think Avid1 AV20 18x9.5 +33 Avid1 AV20 18x8.5 +33 ? i m confuse ! is too late for me . Link to comment Share on other sites More sharing options...
madrig Posted February 24, 2017 Share Posted February 24, 2017 really like the side skirt ! Link to comment Share on other sites More sharing options...
MPacMan15 Posted February 24, 2017 Author Share Posted February 24, 2017 yep av20s the wheels themselves are +38, I run a 5mm spacer effectively making them +33 Link to comment Share on other sites More sharing options...
Sparegun007 Posted February 24, 2017 Share Posted February 24, 2017 Wow that's big, u must have done some rolling and pulling on ur fenders !! I am looking for some 18x8.5 et30 with 225/40/18 Link to comment Share on other sites More sharing options...
Darth SpecB Posted February 24, 2017 Share Posted February 24, 2017 yep av20s the wheels themselves are +38, I run a 5mm spacer effectively making them +33 I would like to run a similar wheel set up. Your fenders don't seem to be rolled, are you lowered? Is there any rubbing or ride sacrifice? Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
MPacMan15 Posted February 25, 2017 Author Share Posted February 25, 2017 I would like to run a similar wheel set up. Your fenders don't seem to be rolled, are you lowered? Is there any rubbing or ride sacrifice? Sent from my SAMSUNG-SM-G900A using Tapatalk Yes the car is lowered quite a bit, it tucks about half of the tire all around. I'm on bc racing coilovers with spc camber bolts in the top strut holes and whiteline camber bushings in the rear, without these you will not be able to run something this agressive, well at this ride height at least. All the fenders are rolled flat, fronts are pulled probably 10mm, front bumper tabs are ground down, relocated and fender liner trimmed. The rear I did have to trim the plastic piece in front of the rear wheel and grind down the metal behind it. The rear never rubs and the front only rubs at full lock in parking lots or over descent sized bumps on fast turns. I would not say it's an easy fit but not to bad lol. Hope that helps Sent from my SAMSUNG-SM-G935A using Tapatalk Link to comment Share on other sites More sharing options...
skrolz Posted February 28, 2017 Share Posted February 28, 2017 Pacman, would you mind posting a close up picture to see what the side skirt ext. fitment is like? I'm interested... Link to comment Share on other sites More sharing options...
MPacMan15 Posted March 1, 2017 Author Share Posted March 1, 2017 Pacman, would you mind posting a close up picture to see what the side skirt ext. fitment is like? I'm interested...[/quote Sure, I'll post some closeups in a bit when I get out of class Link to comment Share on other sites More sharing options...
MPacMan15 Posted March 1, 2017 Author Share Posted March 1, 2017 there's some close ups, last 2 are of the wrx bumper aprons incase anyone was interested on fitment of those too Sent from my SAMSUNG-SM-G935A using Tapatalk Link to comment Share on other sites More sharing options...
