jayrex Posted April 17, 2016 Share Posted April 17, 2016 (edited) After some mild mods to my '05 LGT Wagon, the trans started to slip in 5th, 4th and sometimes even 3rd when I really get on the throttle.(~70%+) This build log will be for the 5EAT. Check out the engine rebuild progress in my other thread:Engine Rebuild Thread I will be installing: ClimberD@HexMods Bullet Proof Diff Bushings ($250)LINK to Thread TransGo Shift Kit ($225) Replacing frictions, steels(maybe), and necessary seals ($200-$800) Also purchased 12 Quart Pack Automatic Transmission Subaru ATF TYPE-HP ($65 shipped from ebay) FYI - This comes in one giant jug, not 12 separate quarts as pictured in the ebay listing. EDIT - Its not one giant jug, that was just an illusion, its 12 bottles. lol This video is boring and not really worth clicking on. Its just a quick walk around of the transmission before disassembly. Just sticking it here as reference for anyone that might need it: Video for removing the valve body: Get yourself a set of vacation pics for this one too, pretty good diagrams in there for this one First Issue (pics below): I purchased a Torx E20 for the three bottom bolts holding the front diff onto the trans. It has a weird (but standard) bevel on the outer rim. This made it barely engage the nut, so it rounded off the top edge of the bolt. I went to three stores trying to find a different E20 Torx, but no luck. So I needed to make modify the one I had. It works great though. I didn't look for it, but alternately you could try to fine a Torx Wrench instead of the socket. You may not need to remove the valve body first if you get the wrench. The socket cut very easily with a dremel, even though it is an impact rated socket. Edited May 24, 2016 by jayrex Link to comment Share on other sites More sharing options...
jayrex Posted April 17, 2016 Author Share Posted April 17, 2016 Still a little more to go, like getting into the sun gear behind the pump there. That one doesn't just slide out like the rest. Getting to this point has been pretty easy so far. No explosion of tiny parts or anything yet. The frictions are all pretty black, the steels look pretty good aside from the weird black marks. I can't even feel those at all, they are perfectly smooth. I might just carefully sand the frictions by taping down some light sandpaper onto a flat surface, not sure yet. Link to comment Share on other sites More sharing options...
west_minist Posted April 17, 2016 Share Posted April 17, 2016 Nice breakdown Link to comment Share on other sites More sharing options...
jayrex Posted April 17, 2016 Author Share Posted April 17, 2016 BIG PROBLEM! Broken teeth in rear differential. Center gear on rear drive shaft. I was putting in the rear diff inserts, and found a broken gear piece. Went searching for the damage. Link to comment Share on other sites More sharing options...
fishbone Posted April 18, 2016 Share Posted April 18, 2016 VERY nice! Thank you for sharing! Great work. Link to comment Share on other sites More sharing options...
jayrex Posted April 18, 2016 Author Share Posted April 18, 2016 (edited) Just a side note: I did not expected to find anything like this when I opened it all up. The whole assembly still worked and rotated pretty smooth. I could maybe see it causing a 'hum', but I didn't really hear anything while driving. The chips were very clean, they had no scratches on them, so they were not bouncing around in there at all. So I purchased a new shaft for $215. p/n 33257AA060 I would like to find the cause, so I can feel confident that it won't happen again. Its three teeth on the gear, and spaced evenly around, although this gear is nested in between 4 others, not three. Something definitive must have caused the extra stress. The only clue is that it broke on the top edge, which makes me think something was not aligned properly, shifted out of position. I found this adjustment, but I'm not even sure it relates. #9(Intermediate shaft) is the shaft in question, and the gear on it is surrounded by four #10's (even though the picture only shows 1) This shaft doesn't even have a bearing on it, so I'm thinking this inspection might be more for the positioning of the rear drive shaft? Edited April 18, 2016 by jayrex Link to comment Share on other sites More sharing options...
whitrzac Posted April 19, 2016 Share Posted April 19, 2016 I think the upgraded center diff bushings fix this. The gears break because the needle bearings in the stock center diff change shape and change the gear mesh. Link to comment Share on other sites More sharing options...
jayrex Posted April 19, 2016 Author Share Posted April 19, 2016 I think the upgraded center diff bushings fix this. The gears break because the needle bearings in the stock center diff change shape and change the gear mesh. I always thought the upgraded bushings were just to prevent them from exploding, but what you are saying makes perfect sense. Link to comment Share on other sites More sharing options...
jayrex Posted April 20, 2016 Author Share Posted April 20, 2016 I finally opened up all the clutch packs (really not that hard - it all comes out in tidy little chunks). Front Brake - Pretty good condition compared to some of the others, but you can see a little burning around the centers. Input Clutch - Definitely the source of the majority of my problems. This one is by far the worst. It doesn't even have any 'tread' left on it. The surface was gritty and crumbling. I could probably replace just this pack and call the whole job done. High/Low/(Rev?) - This one is not looking too good either, almost black. Many of the steels had these black marks on them, but they are almost perfectly smooth. Direct Clutch - also mostly black. The one friction on the end still has a little red left in it. I doubt that one was pulling its weight Reverse - these should be fine, and don't need replacing. Transfer clutches (in the rear extension) - no pics, but they looked good like the reverse clutches. So the last 2 packs(Forward and Low Coast) seem much more 'burried'. They are in the back of the main trans housing. and I'm hoping I don't need to get in there, even for inspection. I think that is where all the bits start falling out. Link to comment Share on other sites More sharing options...
cBax Posted April 20, 2016 Share Posted April 20, 2016 thank you for this! sub'd '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
jayrex Posted April 22, 2016 Author Share Posted April 22, 2016 (edited) Purchased a bunch of steels and frictions from cobratransmission.com They are the first website I found that had online checkout and the 'front brake' parts listed. We'll see if my choice pans out. here's my cart for reference: For example, I was about to use these guys: http://www.makcotransmissionparts.com/5EAT.html but the choices started getting confusing and I didn't see a front brake listed. I even compared my parts to see if the front brake frictions matched any of the others... nope they are different. I was really torn about the steels. I think I could lightly sand to refresh them, but ended up just buying replacements for all but the front brake. I will be buying a few OEM gaskets later, these are thin stamped metal with crazy shaped holes all throughout. I probably could reuse mine, but they are cheap so why not. GASKET-TRANSMISSION CASE,FRONT . Part Number:* 31339AA160 GASKET-TRANSMISSION CASE,REAR . Part Number:* 31337AA200 My costs so far: $200 TransGo Shift Kit $250 HexMods Bullet Proof Bushings $200 Frictions and Steels $230 Broken Intermediate Shaft 33257AA060 (lots of diff part #'s for this) $70 Subaru HP Trans Fluid Total $950 (hopefully) Don't tell my wife unless you want to pay for the divorce. Edited April 22, 2016 by jayrex Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 22, 2016 Share Posted April 22, 2016 Great work!!! In addition to my notes about this in the other thread: Send your steels and that new shaft out to cryo. It will help a lot. Again, also check your planet (pinion) gears during bushing installation. I bet at least one is damaged, more likely all 4. Again, I would replace those two. Purely as coincidence, I'm making 3 more sets of these 5-gear center diff sets, and one has already been sold to a gentleman who likes to drive a certain way that breaks multiple center diffs. They're cryo treated and REM ISF treated (microfinished). Helps a lot. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
jayrex Posted April 22, 2016 Author Share Posted April 22, 2016 (edited) Great work!!! In addition to my notes about this in the other thread: Send your steels and that new shaft out to cryo. It will help a lot. Again, also check your planet (pinion) gears during bushing installation. I bet at least one is damaged, more likely all 4. Again, I would replace those two. Purely as coincidence, I'm making 3 more sets of these 5-gear center diff sets, and one has already been sold to a gentleman who likes to drive a certain way that breaks multiple center diffs. They're cryo treated and REM ISF treated (microfinished). Helps a lot. I double checked the pinion gears, they are all flawless. Thanks for the heads up though, I dont think I gave them a close eye before - at the time I was just looking for huge chunks missing. I'm going to go with "ain't broke, dont fix it" on those =) Thinkin on the cryo. Edited April 28, 2016 by jayrex Link to comment Share on other sites More sharing options...
starionesir Posted April 23, 2016 Share Posted April 23, 2016 Very nice work. I've been thinking about tearing into my transmission for a while now as I rarely drive the car anymore. Any special tools required once inside the transmission? Link to comment Share on other sites More sharing options...
jayrex Posted April 23, 2016 Author Share Posted April 23, 2016 (edited) I've been meaning to write this up a little better because it really isn't that hard and I want to encourage you guys to dig in. The exploded view of the trans really made me want to puke before I actually started getting in there. I thought it would all just fall apart into chaos, but that's not the case - no pun intended. Very nice work. I've been thinking about tearing into my transmission for a while now as I rarely drive the car anymore. Any special tools required once inside the transmission? Not unless you go really deep into the tail section of the main housing. That is where you would get into the forward and low coast packs. Which I'm gambling on being good. There are some T45 bolts that need a long extension. I asked the question on page 82 of ClimberD's 5EAT Question Thread? You can check out what he said there. This is where I 'stopped'. You can see the reverse pack still in there. And that shaft is the broken intermediate shaft that has the center diff assembly gears on the other end. Once you get the front diff off (not too bad), you remove the pump cover bolts(dark in the img), and the rest stay in place. After that, with a few tugs it all comes apart like this: Clutch packs are inside those with snap rings that you only need a flat screw driver and maybe pliers to get hold of, easy. Snap ring pliers won't even help don't bother. The tail section is held on with these bolts: (Note: I print these images, tape them to cardboard and slam the bolts right through the correct location, it works better than drawing on cardboard) Once into the tail section, you are looking at this: Back of main trans housing - **Note close up pic of this later And the section you just pulled off - watch out for that big metal gasket ring in the upper right (dome cover section). I almost didn't notice it because it stuck to the housing. **Close up pic This is where the center diff is... where ClimberD's bushings go... where tears of sadness culminate and cascade over broken diff gears... okay that got dark. I don't think I would pull this whole thing out if you were just doing a diff bushing install. But if you have it on the bench, and stuffs broken, just yank that whole thing outta there - its tight. A snap ring gets you into the diff parts, there's quite a few little washers and things here, so make sure you're over the table and on some clean rags. I popped the new diff inserts in, put the washers on the end and put a zip tie through the pieces. Mine will be sitting for a while until I get the new shaft and I didn't want parts floating around all willy-nilly. The one thing that is REALLY annoying is all the trans fluid, there's always more in there. My work bench is some crappy laminate counter top that I can basically squeege puddles off the edge into an oil catch can. Get it all setup ahead of time so you can catch fluid in a shallow pan and drain it somehow without moving the trans (cuz its pretty heavy until its just the case). Thinking about it now, I should have cut the edges off one of those big black open oil pans, and put a valve or something in the corner/side, with a tube to drain nicely onto floor level. Put some 6" long 4x4's in the box and put the trans on those. Just an idea. Good luck getting it all back together, I don't know how that goes yet. EDIT: I eventually got it back together, keep reading! Edited May 7, 2016 by jayrex Link to comment Share on other sites More sharing options...
jayrex Posted April 23, 2016 Author Share Posted April 23, 2016 (edited) Just ordered this: 31007AA411 GASKET & SEAL KIT-AUTOMATIC TRANSMISSION $118.83+$20 shipping I think 31007AA410 is an old part number and has been superseded by the 411 p/n. The new intermediate shaft didn't come with square seal o-rings in the grooves. The old ones feel like hard plastic and I don't think I can transfer them over. I'm just hoping those seals are in the kit because it is not clear in the exploded diagrams which part that is. My only guess is that they are called ring-seals. I don't know if they are softer new. It will be nice to have some of the o-rings on had to swap out. I needed these larger gaskets in the kit anyway: GASKET-TRANSMISSION CASE,FRONT . Part Number:* 31339AA160*; 31339AA150 (I don't know why there are two part numbers) GASKET-TRANSMISSION CASE,REAR . Part Number:* 31337AA200 Left side is the new shaft, right side is the old shaft. I need to figure out what that tube is in the center and how to transfer it. EDIT: I took another good look at the new shaft and put some light down there. its just a hole about 4 inches deep, it has no passages. I am thinking I do not really need that center tube from the old shaft. I dry fitted the shaft from the tails section into both of these, and the fit was identical, kinda sloppy actually. That tube fits into the extension shaft to add inner alignment along with the outer, but the fit is the same, so its not doing anything. There doesn't seem be be any real function here. Someone please correct me if you have experience with this specific part. Note: I can't pull out the old tube without deforming it. Edited April 25, 2016 by jayrex Link to comment Share on other sites More sharing options...
jayrex Posted April 24, 2016 Author Share Posted April 24, 2016 Put in the TransGo VB mod. Thanks to ClimberD's walkthrough. http://legacygt.com/forums/showthread.php/install-transgo-5eat-hd2-shift-kit-detailed-walkthrough-179771.html Nothing worth noting. It took me about 2 hours start to finish. Disassemble, Modify, Clean, Resemble. Little technical, but pretty straight forward. Link to comment Share on other sites More sharing options...
jayrex Posted April 26, 2016 Author Share Posted April 26, 2016 (edited) Problems 31007AA411 GASKET & SEAL KIT-AUTOMATIC TRANSMISSION This is on backorder, and has an unknown release date. Two Subaru parts dealers said it could be months until (if even) its available. 31007AA410 is what matches my VIN number, but that one is discontinued. I can't get a confirmed answer from any of the part suppliers about 411 actually being the superseded part number. I don't even know if an overhaul kit would have these exact seals (for the shaft). I tried removing them from the old one... not happening. EDIT: I just bailed on the whole gasket kit, I'm going to reassemble with just the big case gaskets that I mentioned before. Edited April 28, 2016 by jayrex Link to comment Share on other sites More sharing options...
jayrex Posted April 27, 2016 Author Share Posted April 27, 2016 Okay I figured out how to swap these rings over... kinda feel dumb now, but it was REALLY hard to see. Link to comment Share on other sites More sharing options...
snow05gtRI Posted April 27, 2016 Share Posted April 27, 2016 ...this is awesome. Link to comment Share on other sites More sharing options...
jayrex Posted April 28, 2016 Author Share Posted April 28, 2016 ...this is awesome. Thanks! More to come, stay tuned. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 28, 2016 Share Posted April 28, 2016 Okay I figured out how to swap these rings over... kinda feel dumb now, but it was REALLY hard to see. I'm just going to PM you my number so you can ask questions without my sometimes long response delays, if you prefer. Keep it up! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
jayrex Posted April 30, 2016 Author Share Posted April 30, 2016 (edited) New frictions, steels, and trans filter. Waiting on some gaskets to come in around mid-next week, but i can get started loading up the packs. EDIT: This trans filter was wrong, did not fit. I just reused the old one. It was pretty clean. Edited May 7, 2016 by jayrex Link to comment Share on other sites More sharing options...
jayrex Posted May 1, 2016 Author Share Posted May 1, 2016 Soaking frictions in trans fluid. They say 20min is fine, but I knew I wasn't going to get into it yesterday, so they've been soaking about 24hrs now. Link to comment Share on other sites More sharing options...
jamesfickackerly Posted May 1, 2016 Share Posted May 1, 2016 I tried to build my transmission but I couldn't so I had to buy a JDM transmission. Link to comment Share on other sites More sharing options...
