Phillip J. Fry Posted April 2, 2016 Share Posted April 2, 2016 anyone have issues with it coming loose? i tightened it the other day and i got a few more 1/4 turns out of it again today. thinking about getting a new clamp installed but was curious how common this may or may not be. Link to comment Share on other sites More sharing options...
Th3Franz Posted April 3, 2016 Share Posted April 3, 2016 It's pretty common for the clamp to loosen up. I recommend upgrading to a t bolt clamp -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
quick4dr Posted April 4, 2016 Share Posted April 4, 2016 tighten it then lockwire it. I use grocery store wire ties and wrap it through the threads so it cant back out. could also dab lock-tight on it, ive seen that method hold very well. Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted April 5, 2016 Author Share Posted April 5, 2016 seems its a little screwy from being over tightened in the past. will be replaced when i change the inlet. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted April 14, 2016 Share Posted April 14, 2016 Rip off that little plastic flap on the TB coupler also, and tbolt yes. Worm clamps loosten overtime, and only apply actual pressure (clampage) on one spot, where a tbolt spreads it out more. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted April 15, 2016 Author Share Posted April 15, 2016 Rip off that little plastic flap on the TB coupler also, and tbolt yes. Worm clamps loosten overtime, and only apply actual pressure (clampage) on one spot, where a tbolt spreads it out more. -Brian i have an avo tb coupler already installed. will look into t-bolt with the rebuild. Link to comment Share on other sites More sharing options...
WahooNo2 Posted April 15, 2016 Share Posted April 15, 2016 ya i had mine break on me too. i got a 3.5 inch clamp from lowes when i did my mishimoto intake hose... i couldnt find anyone locally that had a tbolt. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted April 15, 2016 Share Posted April 15, 2016 ya i had mine break on me too. i got a 3.5 inch clamp from lowes when i did my mishimoto intake hose... i couldnt find anyone locally that had a tbolt. Napa should carry some tbolts in stock. Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted April 15, 2016 Share Posted April 15, 2016 FWIW, I found the T bolt clamps I ordered from a Speed Shop were to big (wide and high) to fit on the TB hose and tmic. So make sure you get ones that will fit. My wagon is at TA currently, or I'd check and see if I used those T bolt clamps on the GS tmic install. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
