islandborn Posted March 31, 2016 Share Posted March 31, 2016 I realized I needed a thread to keep me straight on all the stuff I've done to my Legacy. I have actually used GTEASER's line up (thanks btw!) to guide me. I just can't have my wife find this... 2012 Black on Black Legacy GT Carbon Fiber Interior Trim - Ordered on Feb 09 '12, Received in April of '12. ENGINE AWDTuning Stage2 motor New cases halves bored and honedJE Forged PistonsKing BearingsManley H-Tuff Rods w/ARP 2000 Rod bolts 2012 STi Crankshaft IAG Machined heads JE Headgaskets NGK Iridium One Step Colder 2309 Spark plugs GSC P-D Intake/Exhaust Valves 33mm (+1mm) Gates Timing belt kit w/water pump ARP Head Stud kit 2012 Sti Cams 11mm Sti Oil Pump Injector Dynamics 1000 fuel injectors Deatschwerks 300 Fuel Pump Setrab Series 6 10 row TopMount Oil Cooler (TMIC location) Tial Q Blow Off Valve - 11 PSI - Black BNR 18G Turbo w/ported wastegate IAG Billet Aluminum CNC Top Feed TGV Deletes IAG V2 Top Feed Fuel Rails FueLab Fuel Pressure Gauge Custom FMIC Speed Density AEM Dry Filter Crawford AOS Grimmspeed EBC AVO Catted DP Custom midpipe (removed mid cat) Invidia Q300 CBE Hardrace front engine mount Mazda RX8 Tokyo Roki oil filter Motul 8100 X-cess oil 5W40 93 Octane & E85 maps DRIVETRAIN Clutch kit: ACT SB11 - HDSS Clutch Damper Delete Perrin 2015 WRX Shortthrow Shifter Adapter Perrin 2015 WRX Shortthrow Shifter Stop Perrin 2015 WRX Shifter Bushing OEM STI Shortthrow Shifter Cobb Blue Shift Knob Motul Gear 300 Trans oil SUSPENSION ISC N1 Coilovers ISC RCAs Whiteline Strut Tower Bar Whiteline 22mm Adj. RSB w/ Whiteline Swaybar Lateral Locks Kartboy Endlinks BRAKES DBA 4000 T3 Rotors F&R STI Brembo Calipers F&R Hawk HPS 5.0 Brake Pads Goodridge SS Brakelines Motul RBF 600 Brake Fluid WHEELS & TIRES Enkei Raijin 18X8 Matte Black Bridgestone Potenza S-04 Pole Position GAUGES Cobb AP V3 Defi Red Racer Boost Gauge INTERIOR Weather Tech Mats Arkon Seat Rail Iphone Mount Thinkware 350 dashcam hardwired Uniden R3 radar/laser detector hardwired DAMD blue stitch Steering Wheel EXTERIOR BaysonR V-Limited Front Lip Debadged (except rear Subaru emblem) Blacked-Out Headlight Casings Rear Window Wing Primitive Racing Skidplate C-Mod Grill Hella Horns Prova Side Window Visors Corazon CF Bonnet Scoop LIGHTING Sylvania Silverstar zXe OEM Puddle Lights Morimoto XB LED Fogs Whew! Now I can refer back! Link to comment Share on other sites More sharing options...
steveande Posted April 1, 2016 Share Posted April 1, 2016 Need photos! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted April 1, 2016 Share Posted April 1, 2016 Pics of the bonnet scoop! My "Build" Link to comment Share on other sites More sharing options...
islandborn Posted December 15, 2016 Author Share Posted December 15, 2016 Dashcam and radar detector added...12/15/2016 Link to comment Share on other sites More sharing options...
Humble Rumble Posted December 15, 2016 Share Posted December 15, 2016 Still no pictures 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
islandborn Posted December 15, 2016 Author Share Posted December 15, 2016 I know.. I'll get some up. Link to comment Share on other sites More sharing options...
Ellesedil Posted December 15, 2016 Share Posted December 15, 2016 Still no pictures I snapped a quick picture in passing. http://cdn-static.denofgeek.com/sites/denofgeek/files/2/31//invise.jpg Link to comment Share on other sites More sharing options...
FJuan Posted December 15, 2016 Share Posted December 15, 2016 My wife's balls are delicious. Link to comment Share on other sites More sharing options...
islandborn Posted October 5, 2017 Author Share Posted October 5, 2017 Updated with AWDTunings build list done in October 2017 Link to comment Share on other sites More sharing options...
islandborn Posted February 15, 2018 Author Share Posted February 15, 2018 Finally... some picts from the build.... Link to comment Share on other sites More sharing options...
islandborn Posted February 15, 2018 Author Share Posted February 15, 2018 Updated my build list Link to comment Share on other sites More sharing options...
moral hazard Posted December 13, 2018 Share Posted December 13, 2018 What kind of power did this put down? Link to comment Share on other sites More sharing options...
islandborn Posted December 14, 2018 Author Share Posted December 14, 2018 What kind of power did this put down? E85 sits at 360 whp / 420 wtq - sorta have to wait till 3rd gear to access the power - my trans would pack up and walk away if I launched. However, in 5th and 6th gear, the pull of acceleration is incredibly erotic 93 sits at 320 whp / 350 wtq - just above normal tune numbers. I sat around 290-300 whp / 335-340 wtq Link to comment Share on other sites More sharing options...
islandborn Posted December 14, 2018 Author Share Posted December 14, 2018 The best way to see a bunch of my tunes with the various turbos is via the Cobb Tuning Database. https://www.cobbtuning.com/dyno-database/ In order to get to my car: All shops - pick Cobb Plano Select Make - Subaru (duh) Select Model - Legacy 2.5GT Years - 2012 Select Owner - McCaulley, Shane (the only one, and they added another "l".) You can see the Stage 1 OTS, Protune (stock outside TMIC and CBE), BNR 18g, and the Steamspeed 20g. My present tune was done by AWDTuning hence why its not there. I do have a nice vid Cobb took on that first Protune: https://www.youtube.com/watch?v=IWpIu5uAhx0 In the vid is Calvin Dotson who did all my tuning at Cobb. He now is out on his own tuning. Here is his website. He's brilliant. https://www.dotsontuning.com/ Link to comment Share on other sites More sharing options...
Sarang Posted December 14, 2018 Share Posted December 14, 2018 Wow that really illustrates that the 20g delivers the same power as the 18g with more lag. Link to comment Share on other sites More sharing options...
GTEASER Posted December 14, 2018 Share Posted December 14, 2018 Wow that really illustrates that the 20g delivers the same power as the 18g with more lag.Just as fahr_side had been saying. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
