namtrok Posted March 29, 2016 Share Posted March 29, 2016 hey all, before anyone says anything, ive searched and found answers, just not the answer im looking for. i have an ej22 and im trying to find out if i have interference of non-interference engine. my question is, what physical differences are there between the interference and non-interference ej22s? thanks Link to comment Share on other sites More sharing options...
Osei Posted March 29, 2016 Share Posted March 29, 2016 Your reading in your search was incomplete. All EJ22 engines from 1997 on are interference. Redesigned pistons. O. Link to comment Share on other sites More sharing options...
namtrok Posted March 29, 2016 Author Share Posted March 29, 2016 Your reading in your search was incomplete. All EJ22 engines from 1997 on are interference. Redesigned pistons. O. yeah thats what i found. minus the whole piston thing. any physical differences of the piston face? Link to comment Share on other sites More sharing options...
Osei Posted March 29, 2016 Share Posted March 29, 2016 IIRC the piston was domed(or lengthened) more to increase cr. O Link to comment Share on other sites More sharing options...
Brighton96 Posted March 29, 2016 Share Posted March 29, 2016 Correct me if I'm wrong, but I think the later EJ22s have a different head and a different style valve cover then the early ones. The early 2.2 had the spark plug hole above the valve cover while the later ones had the spark plug going through the valve cover in the same style as the 2.5 Link to comment Share on other sites More sharing options...
Osei Posted March 29, 2016 Share Posted March 29, 2016 Correct me if I'm wrong, ...... You are correct but this was incidental . O. Link to comment Share on other sites More sharing options...
namtrok Posted March 30, 2016 Author Share Posted March 30, 2016 http://i673.photobucket.com/albums/vv99/namtrok/20160311_112615.jpg' alt='20160311_112615.jpg'> this is my piston. does this help any?? Link to comment Share on other sites More sharing options...
Osei Posted March 30, 2016 Share Posted March 30, 2016 I don't understand the question. What pistons you have is irrelevant. What are you trying to do? O. Link to comment Share on other sites More sharing options...
namtrok Posted March 30, 2016 Author Share Posted March 30, 2016 find out if its interference or not. it has a junkyard engine in it, not sure of the year that it came out of. Link to comment Share on other sites More sharing options...
Osei Posted March 30, 2016 Share Posted March 30, 2016 on the pass. side of the block near the stud hole there is a flat surface with the vin on it. Clean it. The 10th digit is for the year. S=95, T=96,V=97 and so on. Unless it has been changed, you can also look under the oil fill cap. It has a mfg year. It will coincide. O. Link to comment Share on other sites More sharing options...
Brighton96 Posted March 30, 2016 Share Posted March 30, 2016 http://i673.photobucket.com/albums/vv99/namtrok/20160311_112615.jpg this is my piston. does this help any?? That is absolutely identical to my 96 2.2 which is non interference. Link to comment Share on other sites More sharing options...
dcthemvp Posted March 30, 2016 Share Posted March 30, 2016 View my post "ej22 identification" just a few underneath yours for vin location on the block. It can be hard to find, but should answer all your questions. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
twisty Posted March 31, 2016 Share Posted March 31, 2016 on the pass. side of the block near the stud hole there is a flat surface with the vin on it. Clean it. The 10th digit is for the year. S=95, T=96,V=97 and so on. Unless it has been changed, you can also look under the oil fill cap. It has a mfg year. It will coincide. O. i always get confused, is it 10th from the left or right? Link to comment Share on other sites More sharing options...
Osei Posted March 31, 2016 Share Posted March 31, 2016 left. As you would read it. O. Link to comment Share on other sites More sharing options...
johnegg Posted March 31, 2016 Share Posted March 31, 2016 in the 90s, it is the letter to the right of the middle. 10th? or 11th? from the beginning.left. starting in 01 it became a number, 1 = 01, 2 = 02...... starting in 2010 it became a letter again. Link to comment Share on other sites More sharing options...
