thisisthenewsic Posted March 22, 2016 Share Posted March 22, 2016 found this browsing online. looks like they just redrilled holes in stock hubs? pretty interesting personally as some people have been wondering if it can be done. http://page21.auctions.yahoo.co.jp/jp/auction/j385345763 Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 22, 2016 Share Posted March 22, 2016 Problem is still same lousy hub assemblies Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted March 22, 2016 Share Posted March 22, 2016 what are your goals? legacy brakes arent that bad. needs better pads though. you know the drill...if you are using abs brakes arent the problem. there are many wheel sizes for 5x100. seems you may be using time and money in a less than constructive way. Link to comment Share on other sites More sharing options...
Phate Posted March 23, 2016 Share Posted March 23, 2016 Problem is still same lousy hub assemblies But you could run a set of badass TL Type-S wheels! Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 23, 2016 Share Posted March 23, 2016 But you could run a set of badass TL Type-S wheels! Uhh..yeah...OK Link to comment Share on other sites More sharing options...
thisisthenewsic Posted March 23, 2016 Author Share Posted March 23, 2016 5x114.3 for better wheel options. u really can't find anything wider than 9" in 5x100 and only reason we have 9" wide now is due to frs/brz production and companies finally seeing the market. i currently already have a great brake setup, coilovers and wheels so it doesn't really pertain to me. i just know some people were looking to try n find a way to go 5x114.3 so i thought id share. Link to comment Share on other sites More sharing options...
Phate Posted March 23, 2016 Share Posted March 23, 2016 Uhh..yeah...OK I can't help my (pre-2007) honda fanboi-ism. 5x114 is where it's at for wheel selection, especially if you want to run something OEM from a different car. But you can certainly do worse than 5x100. You could be 4x114, which is used on all of 7 different vehicles. Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted March 23, 2016 Share Posted March 23, 2016 I can't help my (pre-2007) honda fanboi-ism. 5x114 is where it's at for wheel selection, especially if you want to run something OEM from a different car. But you can certainly do worse than 5x100. You could be 4x114, which is used on all of 7 different vehicles. rpf1 17x9 15.65 lbs 5x100 sadly they didnt have 9's when i got the 17x8's. or are people thinking ricer stretch? Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted March 23, 2016 Share Posted March 23, 2016 5x114.3 for better wheel options. u really can't find anything wider than 9" in 5x100 and only reason we have 9" wide now is due to frs/brz production and companies finally seeing the market. i currently already have a great brake setup, coilovers and wheels so it doesn't really pertain to me. i just know some people were looking to try n find a way to go 5x114.3 so i thought id share. i think some people believe sti is the end of all things. they assume sti has 5x114 so it must be the best. most people here dont even run 245 width tires. why would they need 10's for a 235 and below? because ricecar? Link to comment Share on other sites More sharing options...
Phate Posted March 23, 2016 Share Posted March 23, 2016 i think some people believe sti is the end of all things. they assume sti has 5x114 so it must be the best. most people here dont even run 245 width tires. why would they need 10's for a 235 and below? because ricecar? I like running OEM wheels on lightly modified cars, there are a bunch of nice 5x114's that I like (including newer wrx/sti wheels). Tire stretch is stupid. Link to comment Share on other sites More sharing options...
TheMonaLisa Posted March 25, 2016 Share Posted March 25, 2016 There are plenty of 5x100 choices, you just have to look. An 18x8 with a 225/40/18) tire fills the wheel well nicely. Link to comment Share on other sites More sharing options...
Phate Posted March 25, 2016 Share Posted March 25, 2016 There are plenty of 5x100 choices, you just have to look. An 18x8 with a 225/40/18) tire fills the wheel well nicely. 235/40R18's really fill the wheel wells. Just make sure you're using the correct numbers when calculating the offset, otherwise you'll be doing some significant fender rolling like I am if it's warm enough tomorrow. Next set of tires will probably be 225's, but I can't complain too much because I got the wheels with brand new tires for less than the price of the tires alone. TL;DR: +38 was probably too much. Was used to my hondas where +42 wasn't a big deal at all. #AccidentalStance Link to comment Share on other sites More sharing options...
