capttris Posted March 17, 2016 Share Posted March 17, 2016 I have 66,000 miles on my 2013 and plan to own this car for a very long time. I have had every fluid changed, expect for the power steering and coolant. Yes, I have even changed the CVT once at 50K miles and all diff's have been done twice! ALL work as been done by dealer, except for engine oil changes that I do myself. I had my brake fluid flushed last summer by the Mavis near me, as I figured this was a very easy job and no risk of any real issues. I did this as a preventative only. I had no issues. I have noticed that my brake fluid appears dark. I compared it to a co-worker who just got a brand new Imprezza, and mine is much darker after less than a year old and maybe 15,000 miles. My miles are all 99% highway for work, and I actually pride myself on barely touching the brakes. (to save the brakes and keep the wheels clean). My wheels have normal amounts of brake dust, and I have felt each rotor after a long 100+ mile highway drive and they are all cool and appear normal, so I don't think my calipers are dragging. So why would the brake fluid be so dark in such a short amount of time? My only thought is that Mavis used some cheap fluid that broke down fast. But I find that hard to believe. Sorry for the long post, but I wanted to give a good background on this to answer any questions that I may be able to answer here. thoughts? Would a brake fluid oil analysis tell me anything? thanks in advance Tristan Link to comment Share on other sites More sharing options...
Imprzme Posted March 17, 2016 Share Posted March 17, 2016 Analysis I don't think will tell you anything. Did Mavis actually do a flush or just a bleed? I'm guessing just a bleed and the dark fluid you're seeing is the leftover from the bleed. Link to comment Share on other sites More sharing options...
FLlegacy Posted March 18, 2016 Share Posted March 18, 2016 I would guess they just did a quick bleed as mentioned above. You should use the better part of a full quart of fluid to do a full replacement. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
capttris Posted March 18, 2016 Author Share Posted March 18, 2016 Thanks guys. I am really pissed because I told the service manager several times, very clearly, I want a FULL FLUSH on the brake fluid. My concern is if they used crappy brake fluid and/or the wrong type. Hopefully I just need another flush, done properly this time. thanks Link to comment Share on other sites More sharing options...
DrD123 Posted March 19, 2016 Share Posted March 19, 2016 Would a brake fluid oil analysis tell me anything?Well, you can do all the analysis you need just looking at it - if it's really dark, the color change is due to water uptake - the water does two things - first, it drops the boiling point of the fluid (not really a big deal for most passenger cars - you aren't heating the fluid enough to boil it) - the second thing is the corrosivity of the fluid increases dramatically with water uptake, leading to attack/damage in the caliper which can eventually result in a loss of sealing ability, and a fluid leak. Since a large container of decent brake fluid is around $10 or less, if you are worried, change it out. How quickly the fluid goes bad is really a function of how humid it is where you are, and how often you drive in the rain. (as an example, here brake fluid hardly changes in color after even 3 or 4 years, but we only get around 8" of rain a year, and it's generally very dry here - however, when I was in Virginia, it would darken within a year.) Link to comment Share on other sites More sharing options...
capttris Posted March 21, 2016 Author Share Posted March 21, 2016 DrD123, Thank you, this is valuable info and good common sense stuff that I was overlooking I suppose. I live on Long Island and do a lot of long distance driving for work, including in the rain/sleet/snow, etc. I'm thinking that when I paid for a complete brake system FLUSH, that they probably only "BLED" the lines and just topped off, so it probably looked clean initially. I don't have anyone to help me so I will have to find another shop and explain to them again that I want it FLUSHED. And I guess I will have to watch them this time and make sure. thanks Link to comment Share on other sites More sharing options...
