ej25gt5eat Posted March 16, 2016 Share Posted March 16, 2016 I am almost done my car. I will be putting the motor in next Saturday. I have a Cobb v3. I have a 2008 lgt. I am going to run vf46 with stock injectors unless you guys think I should go bigger injectors I will order them tonight. I did the tgv deletes. I have a Cobb intake , up pipe , turbo back exhaust and a large top mount. Now for boost I was hoping to run Around 22psi. Or what ever the max out of the vf46. Now with the Cobb v3 can I use a Mbc or will I need a electrical boost controller. Now if I do a street tune or a e file tune should I buy a wide band? And if anyone is in se pa that can help me that would be great. I worked for Subaru for years I can rebuild anything. If someone can help me with this I can do a trans for them or help them with anything. I have most of the special tool for the 5 speed rebuild. I just would like to set the Cobb up. This is my second lgt. My first one I got rid of cause I couldn't afford it cause I ended up getting cancer twice now I am clear and super excited about this one. So any advice would be much appreciated . Link to comment Share on other sites More sharing options...
solidxsnake Posted March 16, 2016 Share Posted March 16, 2016 Stock injectors should be fine on a stock VF46. I imagine you'll have trouble hitting 22psi with a stock boost controller, you might want to upgrade to an EBCS. For reference, I have a JmP Custom VF46, and my tune targets around 19psi with a GS EBCS, using max wastegate duties of around 70-75% on the stock wastegate spring. I assume you're planning on getting an actual tune done, and not using a Cobb OTS tune? You should not be running an intake without getting a proper tune, and until you do, I'd stay out of boost. You can likely get an e-tune done from a decent tuner without a wideband, but getting a wideband will speed up and improve the process, for sure. Plenty of e-tuners on the forum here. I'll go ahead and jump in before Max Capacity does () and recommend Tuning Alliance for your tuning needs. Link to comment Share on other sites More sharing options...
Grothe08LGT Posted March 17, 2016 Share Posted March 17, 2016 You should also look into doing an air pump delete! Other than that, think snake hit it all! Link to comment Share on other sites More sharing options...
Thinking out side box Posted March 31, 2016 Share Posted March 31, 2016 It's been a while since the last update, I was busy building and testing before I got enough data to post it up. I built a 3" cold air intake to see if power and gas mileage would be improved. I used a spare stock maf housing and shaved it down to be able to use inline with a 3" pipe and flow stack. At first I ran it as a warm air intake and made tune adjustments based on that. As expected engine leaned out and overboosted, had to increase MAF scale by 25% and reduce Wastegate duty cycle tables by 8% to get it back inline with stock AFR's, Timing, and boost levels. Link to comment Share on other sites More sharing options...
