ssulb Posted March 12, 2016 Share Posted March 12, 2016 I recently removed my headlights and out of curiosity decided to see if the turn signals would hyper flash. So I turned them on and to my surprise, no. They are perfectly fine. No hyper flash. Are the turn signals controlled by a computer or an electrical relay or what? Just curious. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted March 13, 2016 Share Posted March 13, 2016 A flasher would be my guess probably an electro-mechanical one like every subaru before it lol. The same way it doesn't hyper flash with a bulb disconnected it also doesn't get affected by adding trailer lighting to the mix. My guess is a relay along with the flasher mechanism so the flasher itself doesn't "see" the load therefore is not affected by it. The 6th gen is probably different though. Link to comment Share on other sites More sharing options...
Zee199969 Posted March 13, 2016 Share Posted March 13, 2016 There is a flasher module under the dash. The Tapturn module replaces the OEM one to prevent hyperflash with LED turn signals My "Build" Link to comment Share on other sites More sharing options...
ssulb Posted March 13, 2016 Author Share Posted March 13, 2016 I'm guessing that putting LEDs with the OEM flasher wouldn't do anything just like removing the bulbs entirely doesn't do anything. No hyper flash. I do wish I had the Tapturn module. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted March 13, 2016 Share Posted March 13, 2016 I believe what zee said is correct the LED bulbs cause hyperflashing. You will need a tapturn flasher or relay of some sort to run the full set of LED flashers. Link to comment Share on other sites More sharing options...
testa422 Posted March 13, 2016 Share Posted March 13, 2016 Putting led bulbs with the oem flasher will indeed cause hyperblink. Link to comment Share on other sites More sharing options...
fedaykin Posted March 13, 2016 Share Posted March 13, 2016 I recently removed my headlights and out of curiosity decided to see if the turn signals would hyper flash. So I turned them on and to my surprise, no. They are perfectly fine. No hyper flash. Are the turn signals controlled by a computer or an electrical relay or what? Just curious. Sent from my iPhone using Tapatalk Did you trigger left and right or did you press the the hazard button? Link to comment Share on other sites More sharing options...
ssulb Posted March 14, 2016 Author Share Posted March 14, 2016 Did you trigger left and right or did you press the the hazard button? Hazard button, would that be different? I should've tried the left and right but I didn't feel like turning on the ignition. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
testa422 Posted March 14, 2016 Share Posted March 14, 2016 Yes that's seperate Link to comment Share on other sites More sharing options...
ssulb Posted March 14, 2016 Author Share Posted March 14, 2016 Yes that's seperate Oh weird how it is separate from the normal turn indicator flashers. I thought the turn signals might have been controlled by a computer or an electronic flasher but I guess not. Thanks for the replies! Link to comment Share on other sites More sharing options...
fedaykin Posted March 16, 2016 Share Posted March 16, 2016 When I put LED bulbs in my front indicators, hazards were fine but the indicators were hyper flashing. I bought in-line resistors (Philips), which are a simple clip on fix. Link to comment Share on other sites More sharing options...
