fantasyxiv Posted March 12, 2016 Share Posted March 12, 2016 Hi there, I currently have a 2010 LGT which atm performance wise has had the Ecu tuned and also has a 3 port bcs installed on her and I was wondering in terms of the continuation of modifications/ power gains what would be the next best step in terms of parts to add/ replace on her. At the moment I've been considering for my next move either getting minimum a 3" down pipe or getting a full 3"turbo back exhaust system set up on her. If there is something else better or more worthwhile by all means feel free to pass on information. After either the down pipe of full exhaust system whats the next best selection of parts. The mechanic I spoke to recommended in his opinion doing the Fuel pump, fuel rail, injectors, and either turbo high flowing or turbo replacement for memory. I just want to get necessary information in relation to the build process so I have a idea of the direction that I am heading down so I have a rough idea what I'm in for and cost wise ect. Any information would be much appreciated. Link to comment Share on other sites More sharing options...
jackal8788 Posted March 12, 2016 Share Posted March 12, 2016 A downpipe would be your next best step, then the intercooler. You're in Australia so I'm guessing you won't be running e85. If so, the stock fuel system should still support your power through stage 2. No need to upgrade unless you put on a bigger turbo. You will possibly start reaching the limits of the stock clutch with those added upgrades so keep that in mind as well. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
Zee199969 Posted March 12, 2016 Share Posted March 12, 2016 Have you upgraded the bpv yet? My "Build" Link to comment Share on other sites More sharing options...
FLlegacy Posted March 12, 2016 Share Posted March 12, 2016 Probably want to look at a charge pipe as well, the stock one has been known to split under increased boost. A racerx charge pipe with new bpv would be a good addition to what you already have. Link to comment Share on other sites More sharing options...
fahr_side Posted March 12, 2016 Share Posted March 12, 2016 I've never seen a charge pipe go below 22 or 23psi, which is way above what you should be running at stage 1. Stage 2 is best bang for buck but add a metal BPV like the Turbosmart. Sent from a device using some software. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
acumenhokie Posted March 12, 2016 Share Posted March 12, 2016 3"turbo back exhaust, Fuel pump, fuel rail, injectors yes to all except fuel rail. Add intercooler and bpv. Tune for e85 and put a new clutch in shortly there after (if not before or during tune). Link to comment Share on other sites More sharing options...
fantasyxiv Posted March 12, 2016 Author Share Posted March 12, 2016 A downpipe would be your next best step, then the intercooler. You're in Australia so I'm guessing you won't be running e85. If so, the stock fuel system should still support your power through stage 2. No need to upgrade unless you put on a bigger turbo. You will possibly start reaching the limits of the stock clutch with those added upgrades so keep that in mind as well. I can do the E85 tune with the flex fuel set up however E85 availability is limited to only a certain few server-station chains here atm when i looked online recently from memory. Link to comment Share on other sites More sharing options...
fantasyxiv Posted March 12, 2016 Author Share Posted March 12, 2016 Have you upgraded the bpv yet? Nope mine is still the stocker, I was actually looking at those last night, Turbosmart and GFB products. Link to comment Share on other sites More sharing options...
fantasyxiv Posted March 12, 2016 Author Share Posted March 12, 2016 A downpipe would be your next best step, then the intercooler. You're in Australia so I'm guessing you won't be running e85. If so, the stock fuel system should still support your power through stage 2. No need to upgrade unless you put on a bigger turbo. You will possibly start reaching the limits of the stock clutch with those added upgrades so keep that in mind as well. With the down pipe fitment once it's installed that is it i'd assume, no re-tuning after that? Link to comment Share on other sites More sharing options...
Zee199969 Posted March 12, 2016 Share Posted March 12, 2016 Nope mine is still the stocker, I was actually looking at those last night, Turbosmart and GFB products. I've got the GFB Mach 2 and I'm pretty happy with it. My "Build" Link to comment Share on other sites More sharing options...
fantasyxiv Posted March 13, 2016 Author Share Posted March 13, 2016 I've got the GFB Mach 2 and I'm pretty happy with it. I've mainly been looking at GFB mach 2 and Respons TMS range of BOVs atm. Link to comment Share on other sites More sharing options...
