jakeh9890 Posted March 11, 2016 Share Posted March 11, 2016 So I've had this for awhile now and I haven't looked for the problem because I'm assuming it's internal in the trans. What is happening is when I am on deceleration on a flat or downhill in gear Im hearing a gargling noise. It happens consistantly and for the last 15-20kmi. The 02 wrx I had did the same thing and never had a problem for 80kmi so I'm not that worried but when I had brentuning tune the lgt he seemed alarmed so I'm curious I'll take a video tonight of it to get the sound. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2016 Share Posted March 11, 2016 The rear diff, ride in the back seat and see if you can hear it better back there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 11, 2016 Author Share Posted March 11, 2016 Sounds like it's in the trans area but I'll try that. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2016 Share Posted March 11, 2016 You'll be surprised how the sound travels down the propeller shaft. I just had my 5mt gone through again, all new bearings, it clear now that my rear diff is loud under decal. I have learned to coast going down hills, the noise stops then. Learned that many years ago. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 13, 2016 Author Share Posted March 13, 2016 ok so i took a video. i havent been able to ride in the back yet so thatll have to wait but if you listen to the video close you can hear the noise. it kinda sounds like a higher pitched jake brake that is on and off or a kinda grinding but not a nasty grinding. you can start to hear it best around 12 sec the best way to make the noise is the have the trans in a high enough gear so there isnt alot of drag during decel down hill. i.e. 45mph in 5th Link to comment Share on other sites More sharing options...
CapnJack Posted March 14, 2016 Share Posted March 14, 2016 Subscribed for responses. Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 14, 2016 Author Share Posted March 14, 2016 Nobody huh? I guess it's possible it's the throwout bearing. Anybody with an exety clutch ever have an odd noise like this? I had a stock replacement in my WRX and I have a stage 2 in my LGT Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2016 Share Posted March 14, 2016 That's about the same sound my wagon's rear diff makes when doing the same thing. I have learn to put the tranny in neutral and coast down hill if I know there's a stop sign coming up. At highway speeds 70mph that noise is not a issue up and down hills...for the most part. I do plan to pull the rear diff this Spring and have it gone through. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 14, 2016 Author Share Posted March 14, 2016 I'll have to get a better listen from the back seat. I find it odd that with both of the Subaru's I've had I've had the same noise and the wrx I had started making the noise shortly after I did the clutch and as far as I know the rear end was never touched besides fluid changes untill it was crushed due to rust at around 200k mi and it started doing it at like 80 kmi Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2016 Share Posted March 14, 2016 The noise is pretty normal. I LWFW will make it louder also. These cars are known for driveline noise. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 14, 2016 Author Share Posted March 14, 2016 Forgive me but what's lwfw? Lol Im not too worried just curious Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2016 Share Posted March 14, 2016 Light weight fly wheel 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 14, 2016 Author Share Posted March 14, 2016 Yeah just found that in a infamous post lol. I've been out of the loop for so long that I forgot all of the shorthand. My biggest problem is I don't exactly know what's in my car because I bought it with a lot of what's done to it already done I basically just completed the setup and refined it. I have to look at the paperwork again but as far as I know when the clutch was done they replaced the flywheel with another Factory one. After reading the post from Infamous I'm positive that what I'm hearing is some clutch chatter and it makes complete sense to me. I've never actually driven a car with a lightweight flywheel so I can't exactly rule that out but it is a bitch to get my lgt moving.... anybody that ever drive that including seasoned manual transmission drivers stall out once or twice before really getting going but my RPMs don't really drop that quickly so I'm assuming I don't have a LWFW Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2016 Share Posted March 14, 2016 I've had all three FW types in my wagon. Been driving a stick car since I learned to drive on a 1969 VW back then in 1970. I still stall it every now and then. When coasting down hill in neutral, are there any noises you hear ? If you hear noises then...you better have that checked out. My rear diff is quiet when in neutral coasting down hills, at any speed. The 5mt had all new bearing over Xmas, so my noise is not coming from there. The car currently has OEM SMFW. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 14, 2016 Author Share Posted March 14, 2016 No noise in neutral. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2016 Share Posted March 14, 2016 Back at 70,000 miles I had a Spec LWFW installed, the driveline noise increased about that time. At 141,000 miles the rear diff broke. The diff I installed had 32,000 miles on it, it came from a 6mt swap. So this diff has 120,000 miles on it. As I said plan to pull it and have it checked soon. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 14, 2016 Author Share Posted March 14, 2016 So you still figure it's the diff? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2016 Share Posted March 14, 2016 Yes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jakeh9890 Posted March 14, 2016 Author Share Posted March 14, 2016 Damn... I'll have to get in the back seat and listen closer. Maybe I'll be able to hear it if I have it up on the lift spinning? I'll be doing brakes and tires this weekend so I'll try that when I have it up on the lift Link to comment Share on other sites More sharing options...
