Heffernan Posted March 7, 2016 Share Posted March 7, 2016 Just to confirm but the front catalytic converter and headers are one single piece, right? I was searching on RockAuto and that seems to be the case, like I thought, but just wanted to make sure before buying. This is the unit I was going to buy. http://www.rockauto.com/en/moreinfo.php?pk=6350982&cc=1440445&jsn=330 Link to comment Share on other sites More sharing options...
Perscitus Posted March 7, 2016 Share Posted March 7, 2016 Seems like it, good price over @ rockauto too. Even QuirkParts can't beat it: FED-spec? http://www.quirkparts.com/subaru/outback/44620ab24a/2008-year/2-5i-trim/2-5l-h4-gas-engine/exhaust-system-cat/exhaust-components-scat/?part_name=catalytic-converter CALI spec? http://www.quirkparts.com/subaru/outback/44620ab24a/2008-year/2-5i-trim/2-5l-h4-gas-engine/exhaust-system-cat/exhaust-components-scat/?part_name=converter The cross-refs over @ RockAuto seem a bit odd, different Model Years or cars, potentially same engine, same headers. http://www.quirkparts.com/oe-subaru/44620aa740 http://www.quirkparts.com/oe-subaru/44620ab350 http://www.quirkparts.com/oe-subaru/44620ac750 Also odd that RockAuto mentions this as another cross-ref: http://www.quirkparts.com/oe-subaru/44620aa79a Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 9, 2016 Share Posted March 9, 2016 If they have the Walker version I would go with that one. Walker probably makes those for Doorman now that I think about so either is a good choice. Link to comment Share on other sites More sharing options...
Heffernan Posted March 9, 2016 Author Share Posted March 9, 2016 Trying to confirm if the P0420 code shows an issue with the front or rear cat. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 9, 2016 Share Posted March 9, 2016 Before you replace the cat replace both the rear O2 sensor and the front AFR sensor first. Your second cat is merely an additional scrubber that isn't monitored by the ECU. If after those are replaced you still get P0420 its your cat. Link to comment Share on other sites More sharing options...
dgoodhue Posted March 9, 2016 Share Posted March 9, 2016 More often than not its a failing O2 sensor that causes the P0420 code. Link to comment Share on other sites More sharing options...
Heffernan Posted March 9, 2016 Author Share Posted March 9, 2016 Before you replace the cat replace both the rear O2 sensor and the front AFR sensor first. Your second cat is merely an additional scrubber that isn't monitored by the ECU. If after those are replaced you still get P0420 its your cat. More often than not its a failing O2 sensor that causes the P0420 code. OK, so you guys would recommend replacing both upstream and downstream sensors first? Link to comment Share on other sites More sharing options...
dgoodhue Posted March 9, 2016 Share Posted March 9, 2016 I would just do the rear O2 first. If you have a scan tool, I would look at the rear O2 sensor values (even better if you can graph them). Link to comment Share on other sites More sharing options...
Heffernan Posted March 9, 2016 Author Share Posted March 9, 2016 I would just do the rear O2 first. If you have a scan tool, I would look at the rear O2 sensor values (even better if you can graph them). Excuse my 'noobi-ness' but is the rear the upstream or downstream? Link to comment Share on other sites More sharing options...
dgoodhue Posted March 9, 2016 Share Posted March 9, 2016 Downstream Link to comment Share on other sites More sharing options...
