FreeNewt Posted February 26, 2016 Share Posted February 26, 2016 Hello I own a 06 legacy gt and am about to change the exhaust manifold will this manifold work because of the same ej255? http://www.protuninglab.com/hds-swrx02-2p.html Link to comment Share on other sites More sharing options...
Rhitter Posted February 27, 2016 Share Posted February 27, 2016 What is wrong with your OEM headers and why do you want to replace it with a cheap manifold that will not fit right, crack, and leak? My OBXT build Link to comment Share on other sites More sharing options...
coldsoda Posted February 27, 2016 Share Posted February 27, 2016 you don't want to do that.... find another OEM set for sale before you buy that if yours have issues. If your headers are fine, you probably don't need to change them... if you NEED headers, at least make it worthwhile and get a killerb or full race setup. also, consider swain tech for a coating if you do go that route Link to comment Share on other sites More sharing options...
fahr_side Posted February 27, 2016 Share Posted February 27, 2016 Cheap and nasty and still unequal-length. Go equal length or stay stock. Cheapest EL header with some build quality is the Tomei / GTSpec item. Sent from a device using some software. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
