cmdetailing Posted February 16, 2016 Share Posted February 16, 2016 Hello, I just went to put a few gallons in my legacy today and for some reason some fuel started to spill underneath the car as I was pumping gas. While the spill wasn't the entire amount it was definitely audible and visible. Now I thought maybe I was hitting the drain near the gas cap? Later on the drive home I put another gallon that I had in reserve and the car didn't leak? Any thoughts and has this happened to anyone else before? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 17, 2016 Share Posted February 17, 2016 May be there was a problem with hose from the gas pump ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted February 17, 2016 Author Share Posted February 17, 2016 May be there was a problem with hose from the gas pump ? Could have been, I will just have to watch out for any future events. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted February 17, 2016 Share Posted February 17, 2016 I put some gas in from on old jerry can and it did this. The nozzle was too big for the filler hole. I didn't notice until my shoe was soaked in gasoline. Link to comment Share on other sites More sharing options...
cmdetailing Posted February 25, 2016 Author Share Posted February 25, 2016 So I took the car out for a cruise to datalog the vehicle. I stopped by a gas station and put some fuel in the car, next thing I know I hear the fuel spilling out of the bottom. I noticed that it is coming directly below the rear passenger door. I did change the fuel pump so maybe I didn't put the gasket on correctly and it is leaking out? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2016 Share Posted February 26, 2016 So I took the car out for a cruise to datalog the vehicle. I stopped by a gas station and put some fuel in the car, next thing I know I hear the fuel spilling out of the bottom. I noticed that it is coming directly below the rear passenger door. I did change the fuel pump so maybe I didn't put the gasket on correctly and it is leaking out? I guess we all know what you'll be doing this weekend... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted February 26, 2016 Author Share Posted February 26, 2016 I guess we all know what you'll be doing this weekend... Yeah... I am stumped on what the issue could be though? It only leaks when I am putting fuel into the tank? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted February 27, 2016 Share Posted February 27, 2016 Fuel filler hose? Look at all yours hoses, you could have left a clamp loose. Link to comment Share on other sites More sharing options...
