AwdSon Posted February 16, 2016 Share Posted February 16, 2016 Fixed.. Link to comment Share on other sites More sharing options...
whitrzac Posted February 16, 2016 Share Posted February 16, 2016 Not a boost leak. Pre turbo leak. Link to comment Share on other sites More sharing options...
GTEASER Posted February 16, 2016 Share Posted February 16, 2016 Now I am kind of confused as to what exactly I should do. Check every inlet tube connection between the airbox and turbo. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
AwdSon Posted February 16, 2016 Author Share Posted February 16, 2016 Not a boost leak. Pre turbo leak. Either way it would show Smoke test. Link to comment Share on other sites More sharing options...
AwdSon Posted February 16, 2016 Author Share Posted February 16, 2016 Check every inlet tube connection between the airbox and turbo. Everything is gravy. Link to comment Share on other sites More sharing options...
GTEASER Posted February 16, 2016 Share Posted February 16, 2016 Clean your MAF and make sure you have a clean paper or dry filter. How many pounds of pressure was the smoke test done at? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
AwdSon Posted February 16, 2016 Author Share Posted February 16, 2016 Clean your MAF and make sure you have a clean paper or dry filter. How many pounds of pressure was the smoke test done at? I am going to clean MAF, change paper filter, and check o-ring on MAF sensor and ill report back. Dont know what the pounds were, my buddy Brent at Ralli Candy did it. Link to comment Share on other sites More sharing options...
battelready Posted February 17, 2016 Share Posted February 17, 2016 I am going to clean MAF, change paper filter, and check o-ring on MAF sensor and ill report back. Dont know what the pounds were, my buddy Brent at Ralli Candy did it. Ask him at what psi did his smoke tester test to. Also meanwhile dont push it, lean under boost is bad new bears. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 17, 2016 Moderators Share Posted February 17, 2016 In my experience, a shop will not put pressure into the system when smoke testing. My smoke tester only applies about a 1/3 PSI. That can create a problem if you are truly searching for a leak that only occurs in boost. This is one of the reasons I bought my own smoke machine, and it's a great tool to have around. What I do when I'm really searching for a leak is hook up a boost leak tester to the inlet, and then my smoke tester up to the BPV sense hose. This way I can add smoke into the system while depressing the schrader valve on the boost leak tester. Once I see smoke coming out of the boost leak tester I know there is a good amount of smoke in the system. Then I clamp the BPV hose, remove my tester, and pressurize the system at the boost leak tester. Any boost leak should be visible with smoke for at least a moment at that point. I haven't seen a shop do this, but maybe some of them are out there--I don't make a point of going to many shops :/ "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
AwdSon Posted February 17, 2016 Author Share Posted February 17, 2016 Just changed the filter to OEM and cleaned MAF with MAF sensor cleaner. Did 2 data logs and sent them in for review hopefully I find out something soon. Link to comment Share on other sites More sharing options...
compsurge Posted February 17, 2016 Share Posted February 17, 2016 Is your turbo inlet tube gooey? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 17, 2016 Moderators Share Posted February 17, 2016 Is your turbo inlet tube gooey? On a 2010 LGT I wouldn't necessarily assume that. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
AwdSon Posted February 17, 2016 Author Share Posted February 17, 2016 No not gooey. It actually runs perfect, just gotta get to the bottom of this. I am just going to throw the stock down pipe and exhaust on and that should probably clear up the boost creep issue and hopefully sorts the lean out. We shall see Link to comment Share on other sites More sharing options...
Max Capacity Posted February 17, 2016 Share Posted February 17, 2016 IMO putting the stock DP is a waste of time. if you have a air compressor, Block off the inlet hose off the air filter box, on a 4th gen, a pint size paint can fits great. then remove the hose from the BOV on the intercooler. give that hose a short blast of air, put your thumb over the hose and listen for air leaks. Not sure if its that easy on a 5th gen. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AwdSon Posted February 17, 2016 Author Share Posted February 17, 2016 IMO putting the stock DP is a waste of time. if you have a air compressor, Block off the inlet hose off the air filter box, on a 4th gen, a pint size paint can fits great. then remove the hose from the BOV on the intercooler. give that hose a short blast of air, put your thumb over the hose and listen for air leaks. Not sure if its that easy on a 5th gen. There is no leak, I smoke tested it yesterday. Link to comment Share on other sites More sharing options...
