AwdSon Posted January 12, 2016 Author Share Posted January 12, 2016 Justttt when everyone was getting excitied Now you just lost half of us Why is that? Link to comment Share on other sites More sharing options...
AwdSon Posted January 12, 2016 Author Share Posted January 12, 2016 Thanks for the info guys. Link to comment Share on other sites More sharing options...
s2baru Posted January 12, 2016 Share Posted January 12, 2016 Why is that? Just teasin ya...I just got a flood of PMs asking me for my wheels if you didn't want them. They're kind of a big deal Link to comment Share on other sites More sharing options...
AwdSon Posted January 12, 2016 Author Share Posted January 12, 2016 Just teasin ya...I just got a flood of PMs asking me for my wheels if you didn't want them. They're kind of a big deal Nice Link to comment Share on other sites More sharing options...
FLlegacy Posted January 12, 2016 Share Posted January 12, 2016 If I may add, if your quest is for all out power you may lose some comfort and driveability. This is why I mentioned a custom tune over a dyno tune, nothing wrong with that if you really want the numbers just something to be aware of. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
AwdSon Posted January 12, 2016 Author Share Posted January 12, 2016 If I may add, if your quest is for all out power you may lose some comfort and driveability. This is why I mentioned a custom tune over a dyno tune, nothing wrong with that if you really want the numbers just something to be aware of. Sent from my SAMSUNG-SGH-I337 using Tapatalk I don't really want a race car, just a little more power but most of all reliability. Wouldn't a Dyno tune be considered custom, I am not sure what you mean by "custom tune". Link to comment Share on other sites More sharing options...
amidroc Posted January 12, 2016 Share Posted January 12, 2016 If any body can help me with a couple things I would be greatly appreciated, or ad some links. 1. Maintenance schedules. about to hit 60k 2. Recommended oil and oil filter, I have always used Rotella T6 in my other subys. 2B. How much oil? 3. Green coolant recommended like my others? 4. Do I need to dyno tune with Turbo back, or is the Accessport safe enough? Gracias. I had my 60k service completed late last year. http://legacygt.com/forums/showthread.php?p=5243030 Just under $700 from a respectable shop in my area. I listed a pdf of the worm completed. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
Unsp0kn Posted January 12, 2016 Share Posted January 12, 2016 I don't really want a race car, just a little more power but most of all reliability. Wouldn't a Dyno tune be considered custom, I am not sure what you mean by "custom tune". Dyno tune is the best, next up is an E-tune that some tuners will do via emailing data logs, then off-the-shelf COBB maps are tuned on the conservative side, leaving a bit on the table. Link to comment Share on other sites More sharing options...
AwdSon Posted January 12, 2016 Author Share Posted January 12, 2016 Dyno tune is the best, next up is an E-tune that some tuners will do via emailing data logs, then off-the-shelf COBB maps are tuned on the conservative side, leaving a bit on the table. Wouldn't an E-Tune and, and an off the shelf Cobb map be considered the same thing? Link to comment Share on other sites More sharing options...
FLlegacy Posted January 12, 2016 Share Posted January 12, 2016 A custom tune can be a street tune, basically a tuner rides along and makes adjustments on the fly to the map. Personally from a driveability standpoint I would put that above a dynotune. Dyno room is an artificial environment with forced cooling and no traffic, sudden stops... An etune is a custom tune that requires you to log data for the tuner and they make adjustments based on the data until you are both satisfied with the tune. The cobb map is a generic one size fits all tune, so there are definitely improvements that can be made to it. The main thing with the cobb map is your boost is kind of instant, when I did the stage 1 I had to readjust my seating position so I didn't get thrown back away from the wheel if I take off hard in 1st. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
acumenhokie Posted January 12, 2016 Share Posted January 12, 2016 A custom tune can be a street tune, basically a tuner rides along and makes adjustments on the fly to the map. Personally from a driveability standpoint I would put that above a dynotune. Dyno room is an artificial environment with forced cooling and no traffic, sudden stops... Dyno tuning is much better because it's in a controlled environment. You won't find a street turner who is going to tune the top of 4th or 5th gear on the street. Link to comment Share on other sites More sharing options...
Unsp0kn Posted January 12, 2016 Share Posted January 12, 2016 Wouldn't an E-Tune and, and an off the shelf Cobb map be considered the same thing? No, the E-tune will be more specific to your car as the tuner uses your data logs and customizes the tune for you. OTS maps are usually fine, but there's more power there for the taking. It's on my list of things to do, after my zillion other things. As mentioned above, a dyno tune is the best option while also being the most expensive. Link to comment Share on other sites More sharing options...
blklgt05 Posted January 12, 2016 Share Posted January 12, 2016 OP is your grille custom? I like it... mod journal Link to comment Share on other sites More sharing options...
Zee199969 Posted January 12, 2016 Share Posted January 12, 2016 OP is your grille custom? I like it... He says its a CMOD grille in his 1st post, but I don't see the gap at the top that you usually see with CMODs My "Build" Link to comment Share on other sites More sharing options...
FLlegacy Posted January 13, 2016 Share Posted January 13, 2016 Dyno tuning is much better because it's in a controlled environment. You won't find a street turner who is going to tune the top of 4th or 5th gear on the street. I would bet it wouldn't be too hard to find a tuner willing to do it. What are they risking besides their life. Most dynos won't run much over 100 mph I have heard 120 max for safety. How are you tuning the top of 5th if the max dyno speed is reached at top of 4th? Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
AwdSon Posted January 13, 2016 Author Share Posted January 13, 2016 I know of a lot of great tuners in Southern California, Yimi, 5150, Church, Cobb etc.. Does any one know who is good with the Legacy. The reason why I ask is because all though the Legacy platform is almost Identical to the STI/WRX there are some differences from what I have researched, Also not to many of these cars are being tuned opposed to its STI counter parts, so is there any recommendations of a good tuner? Link to comment Share on other sites More sharing options...
FLlegacy Posted January 13, 2016 Share Posted January 13, 2016 Actually our platform is pretty unique, unfortunately. The new wrx is close, but is a 2.0L DIT engine as opposed to our 2.5l port injection. And the STI shares very little with our cars especially where tuning would be concerned. Yes sir our cars are unique sometimes to the point of frustration lol. Personally, I would trust any one of the forum vendors, they have tuned many of the 5th gens on here, and I would be surprised if there wasn't one in your area or at least close enough to take a short trip to. You might check out the vendor section and regional sections and see what you find. Link to comment Share on other sites More sharing options...
Mulenga Posted January 13, 2016 Share Posted January 13, 2016 This is just awesome[emoji7] [emoji7] [emoji7] [emoji106] . Congrats bro, nice find. Sent from my GT-I9100 using Tapatalk Link to comment Share on other sites More sharing options...
AwdSon Posted January 13, 2016 Author Share Posted January 13, 2016 This is just awesome[emoji7] [emoji7] [emoji7] [emoji106] . Congrats bro, nice find. Sent from my GT-I9100 using Tapatalk Thank you. I love the car! Link to comment Share on other sites More sharing options...
nxmb Posted January 28, 2016 Share Posted January 28, 2016 Beautiful! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
