Jordan Posted January 6, 2016 Share Posted January 6, 2016 Hello. So I was using a air pump that plugs into the 12v outlet to put some air in my tires. I only use it when the car is running and have done it several times before. This time I left it on for a little longer and then when I turned my car off it wouldnt start again. It does not crank and no auxilary lights come on. There is no power at all the seats dont move and even when trying to jump it there is nothing. I can however push start it but that is about it. Does anybody have any Ideas? Good thing I just bought another Spec b. (#328)! But still would like to get this one started as it is trapped in my work parking lot! Link to comment Share on other sites More sharing options...
battelready Posted January 6, 2016 Share Posted January 6, 2016 What are you using to jump it? I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
Jordan Posted January 6, 2016 Author Share Posted January 6, 2016 Jump Box Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 6, 2016 Share Posted January 6, 2016 Battery terminal has bad connection. I'll bet you can move one or both of them with your hands without even putting a wrench on them. Link to comment Share on other sites More sharing options...
Jordan Posted January 6, 2016 Author Share Posted January 6, 2016 Ok Thanks Ill check. Link to comment Share on other sites More sharing options...
sanchitosonria Posted January 6, 2016 Share Posted January 6, 2016 Check fuses as well. Link to comment Share on other sites More sharing options...
Jordan Posted January 6, 2016 Author Share Posted January 6, 2016 The terminals were tightened on but I just moved the battery around and it worked! Thanks. Link to comment Share on other sites More sharing options...
Jordan Posted January 6, 2016 Author Share Posted January 6, 2016 I used to live in SLC. Murray to be exact. Link to comment Share on other sites More sharing options...
FJuan Posted January 6, 2016 Share Posted January 6, 2016 Must have blown a fuse or relay. Check all the fuses in the engine bay. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
battelready Posted January 6, 2016 Share Posted January 6, 2016 The terminals were tightened on but I just moved the battery around and it worked! Thanks. Check to make sure there isnt any white stuff on the terminals. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
FJuan Posted January 6, 2016 Share Posted January 6, 2016 Opps, I missed the part that he got it started with the battery terminals. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
