Dancog70 Posted December 24, 2015 Share Posted December 24, 2015 Broke my timing belt and need to swap my heads and replace the timing belt kit w/water pump. My buddy says I have a second generation EJ22. I'm having a tough time finding a gasket kit for the 1999 for under $350. I keep finding kits for a 2.5l for cheap. Manufacturer date is 12/98, title says 1999. Can I use the gasket kit for a 1998 EJ22? I am planning on pulling the engine to do the head swap so I'll be doing the clutch as well. Link to comment Share on other sites More sharing options...
Jdubgt530 Posted December 24, 2015 Share Posted December 24, 2015 You don't want to cheap out on gaskets. Get good quality gaskets so it is done and won't needed to be done again for awhile. Since your car was a late produced 98 it was grand fathered into 1999, same things with my 97, it was grandfathered in from 96 to 97. A lot of the parts I find that are the right ones are the 96 year ones so shoot for the 98 kit. Look up 5 star gaskets, they are a bit pricey but like I said you will only need to do it once for awhile Link to comment Share on other sites More sharing options...
johnegg Posted December 24, 2015 Share Posted December 24, 2015 i would just order the head gaskets from an online dealer. you get the subaru gasket, you pay wholesale, and you don't waste money on a bunch of gaskets you don't need. most head gasket kits are actually ''rebuild'' kits with tons of stuff you will not need. you need head gaskets intake and exhaust gaskets and water pump gasket other stuff you may consider, cam and crank seals oil pump o-ring valve cover gaskets i used felpro intake and exhaust gaskets from the local parts store. but i would price them from an online dealer. and i would order everything all at once. good luck. Link to comment Share on other sites More sharing options...
Dancog70 Posted December 24, 2015 Author Share Posted December 24, 2015 So with a BK model code and a EJ22ICWAWL engine code and a manufacturer date of 12/98. Am I okay to use a head gasket kit that is said to be for 90-98 SOHC EJ22E ? Link to comment Share on other sites More sharing options...
johnegg Posted December 25, 2015 Share Posted December 25, 2015 yours is a phase 2 engine, not a phase 1. i di not know that it will work. but since you can swap blocks between the two, it probably will. but i say why risk it. that's just me. good luck. Link to comment Share on other sites More sharing options...
Osei Posted December 27, 2015 Share Posted December 27, 2015 The 99 2.2 uses the same HG as a 98. They changed the intakes, which match with the 2.5 sohc. plus some other changes The 2.2 gasket is composite fiber and does not have issues. Get oem or Fel pro. Make sure its for the 2.2. The inner 2 head bolts may be different than the outer 4. If so they are are color coded. Be sure to put them back properly. RockAuto has the Fel Pro kit for $171. Look up a coupon which will save you 5%. O. Link to comment Share on other sites More sharing options...
Tr00b Posted January 2, 2016 Share Posted January 2, 2016 Order the specific head gasket from the dealer off your vin. This model year is extremely tricky. The weird models also has oddball valve seals (or dealer gave me wrong ones), a unique timing belt length and no egr. It is in between phase 2 and the 3rd gen. motors. My gasket was mls and the dealer replacement was mls. Regardless of the condition of the heads I'd plane them and have the valves gone through. I got most of the parts and seals from the dealer and had my heads reworked by the dealers machine shop they use for about $1000 YMMV... The machine shop the dealer uses had never seen one of these come in... Ever. Link to comment Share on other sites More sharing options...
